It is currently Wed May 27, 2026 9:44 am
 Post subject: Wheel Hub problem
PostPosted: Tue Jun 22, 2010 5:31 am
Hello, I got the same porblem as in this thread: http://slantsix.org/forum/viewtopic.php ... c&start=15
But I am going to buy a used one instead of reparing it and I have not found a place that sells them new.
What i am wondering is that i have a valiant from -67 with orginal disc brakes with 4 piston calipers, Are there same hubs on the newer with one piston brakes or even on the ones with drumbrakes? I have seen that the newer disc brakes and 10" drums have the same bearings. But does they have the same bolt pattern?
And does any store that sells the hub without the disc?
PostPosted: Tue Jun 22, 2010 4:26 pm
I have a hub from a '72 Dart I will sell you.
,Cliff
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Wed Jul 14, 2010 7:51 am
Thanks but I am from sweden so the shipping will be huge i think.
Still need to know if its the same hub on drums/discs and if its the same hub on the new/old diac brakes.
PostPosted: Wed Jul 14, 2010 8:01 am
The '73 and newer hubs will not work on a '72 and older car as the wheel bearings are different. I'm pretty sure you'll have to find an old Kelsey-Hayes rotor with a good hub.
