It is currently Thu Jun 18, 2026 4:01 am
 Post subject: valve stem seal
PostPosted: Thu Jul 15, 2010 10:01 am
Hi!
How change valve stem seal tell me please
Satellite Wagon'72
PostPosted: Thu Jul 15, 2010 8:27 pm
in car???? small piece of cord ,thread into cylinder,turn over by hasnd ti hold valves in place, spring compressor to compress spring, remove keepers , spring ....replace seal ...reinstall spring,keepers,,, remove compressor ....other valve same cylinder ,repete,,,, back off piston from cord ,remove ....next cylinder
dont forget to use little straw on valve to slide seal on ....touch of grease/oil helps slide also
keep on roddin'
PostPosted: Thu Jul 15, 2010 9:46 pm
tnx, but just cant understand 'bout 'small piece of cord', what it's mean?
Satellite Wagon'72
PostPosted: Thu Jul 15, 2010 10:03 pm
The cord is used in conjunction with the piston to keep the valves from falling into the engine while the keepers are off.
Two other ways to do it;
1. Get an air fitting to install in place of the spark plug. Use a regulator, and hold around 30 PSI of air pressure on each cylinder as you pull the valve springs. Follow hantayo's instructions on removal of the springs. Do not let the pressure go while you have the keepers off. You'll be pulling the head if that happens.
2. Remove the head and follow hantayo's instructions for spring removal.
PostPosted: Thu Jul 15, 2010 10:40 pm
"cord" is also know as "rope" or "line" or "sheet" depending on what context it is being used in. I can understand the confusion with translating from "English". Too many word to represent the same thing... and different "slang" used too..
Mike
An officialis Tyrde-Browne Racing membrum
PostPosted: Thu Jul 15, 2010 11:35 pm
Keep a close eye on the keepers when you remove them, they tend to end up where they should not be (like the oil pan :oops: )
PostPosted: Fri Jul 16, 2010 12:54 am
The engine, which I was involved - the valve did not fall in principle. Rested on the pistons
Satellite Wagon'72
PostPosted: Fri Jul 16, 2010 9:58 am
I use a length of vacuum hose and cram it into the cylinder on compression stroke.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 4 guests
