It is currently Thu Nov 26, 2026 4:02 pm
PostPosted: Sat Jul 19, 2003 6:57 pm
Quick intro: I've got a '78 Dodge (of course) D150 2WD pickup that I've had for about 8,000 miles.
It's dieseling quite a bit when I shut it off now (record time is like 4 seconds of dieseling a month or so ago, now I never let it go for more than a second before manually killing it with the clutch so it might be worse), and I have no idea why.
Here's a rundown of what I've done with it since I've had it, in case any of this info's important: When I first bought it it killed at idle and was very hard to start, so I rebuilt the carb first thing, and made sure to set all the adjustable parts back to the way they were. This fixed the killing-at-idle problem but it was still hard to start after sitting for more than a few hours (this got WAY worse as time went on) and SEVERELY underpowered, like top speed 65mph kind of underpowered. The hard starting thing necessitated taking off the air cleaner so that the choke could close itself all the way, I suppose it wasn't the stock air cleaner, and one day when it was 10 below in January I noticed plumes of vapor coming up out of the manifold. I replaced that, very sloppily I might add thanks to the freezing weather, and also cleaned out the bumpy area between the two manifolds that was loaded with carbon deposits. This definitely solved the power problem (it still has all that power) but again it only solved the starting problem for a week or two, then it quickly got worse.
About two months ago I had my dad mess with the timing, and it seemed to help, but only for a bit. At the time it was EXTREMELY hard to start and was dieseling just a little bit, maybe half a second or so. About 3 weeks ago the starting problem got so bad that it was barely starting when using starting fluid, plus it was getting short bursts of power loss at 60+mph, so I cracked open the carb and cleaned out everything, and set the float as high as it would go per my dad's recommendation. It started much better after sitting for even a couple days at a time and it ran smooth on the freeway but still dieseled (I should note that sometimes it wouldn't diesel at all, but it seemed random...5 minute trip it might diesel like crazy, 2 hours on the freeway and it might shut right off).
We just got back from an 8-day vacation, so the truck was sitting the whole time, and it took a LOT of starting fluid to get going, and when I parked it after the initial 30-minute drive it dieseled for a good 3 or 4 seconds before I remembered to kill it. It still runs perfectly well as far as I can tell, and the gas mileage is probably pretty much the same as it's been, I haven't filled the tank up all at once in awhile but it doesn't seem to be sucking it down noticeably more.
So...anyone have any idea what's up?
PostPosted: Sat Jul 19, 2003 8:36 pm
I Feel obligated to reply first because I own a 78 d150 and I was born and raised in(mostly) in Minnesota I think you have two or possibly three problems. When you put on the brakes is there a funny fluttering air noise inside the cab? I say this because your truck has vacume assited powerbrakes And when the rubber parts in the booster start to leak, long before you have brakeing loss, your engine is dealing with a huge and sometimes intermittant vacume leak this causes a lean mixture resulting in an excessive carbon build up in the conbustion chambers this raises the compression ratio a bit and provides a home for small glowing embers(And you got a desel). as for the hard starting it could be a fuel dilivery problem seance you may not know how many miles are on the fuel pump it would be a good time to replace it (again more old rotting rubber) You dident mention a fuel filter Is it constantly getting weird crud in it? Its a pain in the arse but I had to do it, I'm talking about droping the gas tank and cleaning it out and I know you got to replace all the rubber fuelline and vent line above the tank because because by now its all rotten and maybe leaking allready and the fuel pump might be sucking air,make sure the white plastic vent valve is still working(do you get a woosh sound when you take off the gas cap?)Again about hard starting, pull a plug wire and see if it arcs cheak that the coil wire connections are good, Its been my experiance that the electronic ignition eather works good or not at all but it needs clean sparkplugs and wires that are not old and rotten sorry,more rubber comments. I'm assuming the compression is good the carb was rebuilt to the specks on the rebuild kit sheet and that the timeing is at least in the ballpark. take some carberator cleaner and spray it around (a little bit) where you took off the intake manifold and carberator if the engine speeds up a bit you have found another vacume leek , use the same carb cleaner to clean the PVC valve or better yet replace it . I like the older trucks they usualy very relyable as long as I Replace the parts I know have a limited life time before they fail. I enjoy doing this at a time of my choseing, wearing coveralls with all my tools better than on the side of the road when I'm suppose to be some where Thanks for listening Bruce Johnson
78b4ramSnortbed/6
PostPosted: Sat Jul 19, 2003 9:30 pm
I hope I don't offend anyone, but as far as I know, it's rich mixtures that cause carbon build up. Lean mixtures burn really clean and won't usually even soot up the tailpipe much. Again, I'm not trying to offend anyone, I just wanted to throw my two cents in in case it could save someone some trouble.
PostPosted: Sat Jul 19, 2003 9:53 pm
The carbon buildup could definitely be the problem...I don't think I've got a vacuum leak now, but I had a MAJOR vacuum leak for a long time of course, with the manifold gasket. I'll check for more leaks anyway. I haven't had a disposable fuel filter on for quite awhile since the last one broke while I was taking off the carb, but it seemed pretty clean to me. However, there's some kind of odd contraption that I guessed was probably a fuel filter between the carb and fuel line... it's all metal with a small glass bowl off to the side. I've never figured out what it was, but it might be the problem.
The previous owner replaced the fuel pump right before I bought the truck, but it would be worth checking out too. Obviously it's doing SOMETHING since the truck runs, but it seems like gas is draining out of the float bowl or somewhere and I have to pump the pedal a lot in the best case, or run the engine on gas down the carb's throat or starting fluid until enough gets pumped into the carb to keep it going.
Bruce, since you have the same vehicle as me, maybe you can answer this question... what's the little cylindrical electrical thing attached to the valve cover near the middle of the engine, on the manifold side? When I got the truck it wasn't plugged into anything and I couldn't figure out where it should go. I assumed it was some kind of pollution control thing but I have no clue.
PostPosted: Mon Jul 21, 2003 9:10 am
dont know, mine didnt have one but mine was a forest service truck They came with the option of quite a few differant "deletions. Sorry I got turned around technically on the carbon thing just trying to relate some of the problems I had over the years with my truck, Bruce J
78b4ramSnortbed/6
PostPosted: Mon Jul 21, 2003 12:43 pm
The Cylindrical device mounted to the valve cover is a "Vacuum Amplifier" for the EGR. It hooks up to a vacuum port on the Carb, (or the manifold,) and to a temperature switch that should be on the radiator. The resulting signal drives the EGR Valve.
You should be able to leave that disconnected, so long as the vacuum source that it was tied into is plugged. I have been unable to locate a supply for the Vacuum Amplifier on my Valiant. It has been discontinued by Daimler/Chrysler. Too old...
PostPosted: Mon Jul 21, 2003 1:09 pm
Good to know that thing isn't useful... even if I found a place to plug the wire in, the vacuum tree hookup thing on the intake manifold broke off when I tried to remove it, so I just replaced it with a plumbing fitting from Menard's so the power booster would still work. Fit perfectly, too!
To completely eliminate the possibility of an ignition problem, how much stuff would I need to replace and how much would it all cost? Can you "tune-up" a distributor this new?
Also, what can I do about carbon deposits short of taking the head off the engine?
PostPosted: Mon Jul 21, 2003 2:50 pm
Run a cup of water thru the engine at a fast idle, this will "stream clean" away the carbon build up.
 Post subject: Err....
PostPosted: Mon Jul 21, 2003 10:45 pm
I'm voting for the power booster failure as a vacuum leak and probably causing #6 to go lean and causing it to run badly....(you can get the truck warmed up, pull the hose off #6, cap it with a rubber plug or peice of hose with a bolt screwed into it as a cap and see what that does.....).
If you follow kesteb's advice (it really does work....), warm engine up to operating temp, put engine into fast idle, slowly mist or pour water into the carb (if you dump it in it'll choke or worse...), just a small amount over a long period of time... there will be lots of steam and maybe some grey smoke if you really got some crud out of there..... the idle will act like it's about to cut out, back off if it sounds like it's about to quit....
PostPosted: Mon Jul 21, 2003 10:51 pm
No problem-I wasn't trying to bust your chops. I just didn't want a misunderstanding to send someone in the wrong direction.
PostPosted: Tue Jul 22, 2003 8:17 am
I don't think it's the booster...I actually replaced that before when I thought it might be causing the vacuum leak I was having (which turned out to be the manifold gasket). When I installed it it wasn't really any different. I'll try plugging the vacuum fitting anyway though.
PostPosted: Wed Jul 23, 2003 11:27 pm
droping the gas tank is a real pain acouple of nuts are only accesable with the bed off (which I dident do) I just cut them and replaced them with some toggle bolts during the reinstall there is allot of rubber hose that should be replaced above the tank from not only the relyability stand point but also for safety, like it would be nice during a rollover, god for bid, the factory vent valve can perform as it should, its mounted on a cross member after a lenght of 25 year old hose Ican send you pictures of my fuel cell installation if some day you want to install an exhast system on the drivers side of the truck. Bruce Johnson
78b4ramSnortbed/6
PostPosted: Fri Jul 25, 2003 7:20 am
" The hard starting thing necessitated taking off the air cleaner so that the choke could close itself all the way"
If the air cleaner is actually interfering with the choke operation, is it possible that it is also interfering with the idle settings, causing the engine to run-on after ignition-off? If you haven't done so already, try to recreate the situation where the engine "diesels", only remove the air cleaner before you shut it down.
If the air cleaner isn't the stocker, I would definitely deep-six it and use the factory unit.
Someone mentioned the removal of the fuel tank and it got me wondering if you possibly have rust thru on your fuel sending unit nipples or (as was already mentioned) deteriorated hoses, which could cause the hard starting after the truck sits for a long period.
Users browsing this forum: 72polara, Ahrefs [Bot], malrv1 and 16 guests
