It is currently Thu Nov 26, 2026 10:02 am
PostPosted: Sun Jul 20, 2003 5:46 pm
Are there any larger distributors that'd be more able to handle fat wires with large boots than our stock small distributors can? I've been parusing the Mallory and MSD catalogs and wondering what other options we've got along with an MSD setup and the MP electronic conversion.
PostPosted: Sun Jul 20, 2003 7:39 pm
How much bigger of a boot do you want? I am using msd superconductor 8.5mm wires with the right angle boots it came with. Those are relatively thick. I can't remember what aftermarket manufacturer did but there was one that listed a distributor for the /6.. I think pertronix? It was the company that makes those pickups you can install in any distributor to replace the points. I highly doubt it used a bigger cap though.
PostPosted: Sun Jul 20, 2003 8:03 pm
I had been told (but haven't seen for myself) that the Magnecor 8.5mm wires use a connector that's too large for the stock distributor to accept. I found it hard to believe, since it IS made for a /6, but thought I'd investigate my options as a "just in case".
Though I'm thinking now that instead of the Mopar electronic conversion, I'll either build an MSD system, or use a Pertronix setup. Now for when I upgrade the coil, for bypassing the ballast resistor, am I able to just splice the wires together and call it good? I noticed that there is an extra wire that's spliced to each one that seems to be related to the dual field electrical system, and I don't want to screw anything up when the time comes.
PostPosted: Mon Jul 21, 2003 12:15 am
I am not using the stock regulator/alternator, so I just left my regulator unplugged and left everything with the ballast as is. I ran all new wires with my msd 6a and blaster2 coil. Go to msd's site and see if you can download the manual. Otherwise, the instructions in the box are very clear and easy to follow.
As for plug wires... well, if the 50ohm/foot 8.5mm supercondoctor msd's can contain a spark that the blaster2 coil produces (can jump over 2 inches in air!) I'm more then satisfied with them.
PostPosted: Mon Jul 21, 2003 1:30 am
You unplugged the regulator and left the ballast resistor in place???
I don't get it :?
PostPosted: Mon Jul 21, 2003 2:02 am
The regulator is useless to me because I am using a 1 wire alternator. only reason I left the ballast connections in place was because I didn't know if any other part of the harness connected to it besides ignition and alternator/regulator, so I figured it would be easier if I just left it on. Besides, what does it save if I removed it, a whole 1/4 pound? :)
PostPosted: Mon Jul 21, 2003 2:40 am
Oh yeah, I forgot you're using a one wire alt. Silly me :oops:
I oughta trace the wiring diagram and see how much of the ballast resistor and its wires I can ditch when I upgrade the ignition. Not that I care about weight, I'm just meticulous (or anal) when it comes to extra stuff there that's not needed...
PostPosted: Mon Jul 21, 2003 3:20 am
I left all of my original wiring as is because if I ever have issues and need to go back to stock everything is plug and play. I suggest you do the same, you never know when it will become handy. I say just tie it up out of the way and spend your time for a more worthy cause on the car.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot] and 17 guests
