It is currently Sun May 17, 2026 7:53 am
 Post subject: Sway bar on a '63
PostPosted: Tue Jul 20, 2010 8:17 pm
Are there any special brackets or mounts that I will need to look for?
I am making and welding my own LCA mounts and buying the hoop mounts. Am I missing anything special?
,Cliff
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Wed Jul 21, 2010 3:26 am
You have the parts lits right. :) If you have the bar correct, when mounted to the lower control arms. I found that 1" of tension pushing the bar where straps can then bolt on, is just fine. More than that if your cornering hard. :shock:
'72 Image Duster /6 with turbo build up
'03 Ram 2500 4x4 w/HEMI 5sp 4:10 posi
My Twister Page
PostPosted: Wed Jul 21, 2010 6:31 am
Stock 62-66 sway bar?? Addco?
