It is currently Tue May 19, 2026 10:47 pm
PostPosted: Mon Jul 26, 2010 1:46 am
I am running a mopar electronic ignition on my slant with a double ballist resistor.Can i bypass the resistor?I'm running a 12 volt bosch gt40 coil :roll:
Another AP5 valiant still going strong.
PostPosted: Mon Jul 26, 2010 8:27 am
Not with the ignition box you have now.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Mon Jul 26, 2010 4:14 pm
Ok thanks for that. :D
PostPosted: Mon Jul 26, 2010 5:36 pm
If you use a 3 ohm coil, you can delete the ballast resistor.
PostPosted: Tue Jul 27, 2010 2:20 am
Ok how do you find out if you've got a 3 ohm coil?It's just a bosch gt40. :D
PostPosted: Tue Jul 27, 2010 2:59 am
Ohmmeter
:wink:
PostPosted: Thu Jul 29, 2010 10:05 am
Or get a Pertronix coil. They list resistance values on their spec sheets. You can down load the pdf from their website. www.pertronix.com
I am running the 60,000 volt HEI style. They make them in (3) different ohm ratings for racing applications. I am using part #60130. Click on the red link below my name to view the coil.
PostPosted: Thu Aug 05, 2010 8:52 pm
Ok thanks ted,i'm back in town from work will go shopping and see whats in the parts stores.My ignition module is just the silver colour, is it still ok to delete the ballast resistor if i get a 3 ohm coil?
PostPosted: Thu Aug 05, 2010 9:54 pm
Yes!
