It is currently Tue Nov 24, 2026 9:55 am
PostPosted: Mon Jul 26, 2010 2:38 am
I bought an '84 D-150 with an Overdrive-4, slant six (3.7 225). New carburetor, distributor, cap, rotor, wires, and plugs. I had it running really good, considering how it WAS running when I purchased it. I took it on a 300 mile endurance run...I babied it... I got to my destination with minimal problems. I get in it to go back the 300 miles home the next day, and I had massive blow by, and no power. I attempted to drive it, 50 miles into the trip back, I had dumped about 3 quarts of oil into it. I shut it down and had a friend dolly me home. Now I've heard that my compression ring(s) in one or more cylinders, and I've also heard that my timing chain had severly streched, and that my head gasket may have ruptured (but I'm not loosing any coolant). I have yet to do a compression test on it, but it is planned.
If anyone has any comments or advice on the matter, I would deeply appreciate it, thank you.
1984 Dodge D-150 1/2 ton 2WD short box. 3.7 225 Slant Six
PostPosted: Mon Jul 26, 2010 6:35 am
Welcome to the site!
I'm no expert here, but it sounds like it might be time for a rebuild. Did you do another compression test?
Other guys will respond here, so check back here.
Again, welcome to the site!
'78 Volare 225
'67 Charger 318
PostPosted: Mon Jul 26, 2010 9:04 am
How many miles are on this engine?
It sure sounds like a ring problem... is the fuel system in good condition, no "bad gas" that could have "stuck" the rings?
If there are a lot of miles on the engine, it could have a couple of broken rings, a compression / leak-down check will tell the story.
PostPosted: Mon Jul 26, 2010 1:09 pm
NTDpruett,
Did you recently acquire this truck, and up until this 300 mile run had you driven it much? Have you performed a recent oil change?
If you just got the truck, have not driven it much, and recently changed the oil, I’m betting previous owner used 20/50 oil, and a can or two of ring seal "snake oil".
PostPosted: Mon Jul 26, 2010 9:43 pm
I've had the truck for about a month and a half, two months. Been driving it back and forth to work regularly. I had a slight miss and thought it was carburation, so I replaced it. Still had a slight miss, so I gave it a FULL tune up, cap, rotor, wires, plugs, points, condensor, and distributor. It seemed to have cure the miss, so I gave it an oil change, and away I went on the 300 mile run.
I did manage to do a compression test, the readings are as follows:
#1 115 psi
#2 118 psi
#3 26 psi
#4 28 psi
#5 24 psi
#6 114 psi
As you can see, the #3, 4, and 5 cylinders are nauseatingly low. I've never seen exactly half of an engine not having proper compression. In theory, I've been thinking that the head gasket may be ruptured between cylinders 4 and 3, and 5 and 3. Which would make sense to the degree of having the blow by coming from one or more of the intake valve seals...But, again, I don't exactly know. Well, I hope to hear from you guys on this matter, and thanks in advance.
PostPosted: Tue Oct 05, 2010 10:51 pm
Did you ever figure it out?
