It is currently Tue May 26, 2026 8:00 am
 Post subject: getting old gaskets off?
PostPosted: Mon Jul 26, 2010 5:06 am
What should I use to get old nasty gaskets off?
I am working on my cherokee oilpan gasket, and there is a lot of stuff in the way, and the gasket is pretty tough to get off.
Can I use acetone to soften the gasket a bit?
Paint stripper?
Torch?
I just don't want to WALK 2 hours to town to get gasket remover spray, if I can use something around the house... :roll:
PostPosted: Mon Jul 26, 2010 8:33 am
Goof off or lacquer thinner.Very flammable so be careful.
PostPosted: Mon Jul 26, 2010 8:45 am
Goof off works ok when there is just a little bit of stubborn gasket left. If it's the thick stuff I'd go with a torch and scraper. Even a fine wire wheel if some of it is a little stubborn.
PostPosted: Thu Jul 29, 2010 1:56 pm
Thanks!
Uhm...I ended up squirting some gas on them, and put them on fire... :roll:
Don't try this at home!
Oh, they came off pretty easy after that.
Guess I am going to town to get something safer now 8)
