It is currently Thu May 14, 2026 6:44 pm
 Post subject: Disc spindle bolt length
PostPosted: Mon Jul 26, 2010 7:17 am
I'm just getting around to installing the disc brake spindles I picked up at the local yard. They are from a late 80s Diplomat and I'm installing them on my 71 Satellite.
I ran into an issue with the bolts that attach the new spindle to the lower ball joint/steering arm. The original bolts are now too long and the bolts that came with the spindles are too short.
I'm thinking of using some grade 8 bolts and nuts from the hardware store along with some locktite. Before doing this I'd like to know if grade 8 would be correct for this application or if someone has a better idea. Thanks.
PostPosted: Mon Jul 26, 2010 10:20 am
I have used grade 8 from the hardware store with no problems.
PostPosted: Mon Jul 26, 2010 11:44 am
That's good to know. I wasn't sure if grade 8 would be strong enough/too brittle etc. Wouldn't want the wheel assemble to head south while I'm heading north. Thanks.
