It is currently Mon Jun 15, 2026 2:03 am
 Post subject: clattering rocker arm
PostPosted: Tue Jul 27, 2010 6:16 pm
Hello, one of my rocker arms is clattering, I think I have a stuck lifter, all the other 11 rocker arms are fine, can someone please guide me in the right direction in solving this issue. Thanks again Pat
PostPosted: Tue Jul 27, 2010 6:52 pm
If it's a solid lifter engine you just need to adjust it. There are multiple threads on here on valve adjustment.
If it's a hydraulic motor you could have a bad lifter or worse. :shock:
PostPosted: Wed Jul 28, 2010 9:00 am
What year is the engine / vehicle?
PostPosted: Sat Jul 31, 2010 9:10 am
It is a 1970 dodge dart 225 3.7L, I just put some kroil down in there, but if that doesn't work I need to know where to start thanks
PostPosted: Sat Jul 31, 2010 9:30 am
Search this forum for lifter adjustment--- -- pop the valve cover off & idle the motor--- check the movement of your rocker gear-- you'll have it purring in no time, Lawrence
PostPosted: Sat Jul 31, 2010 9:32 am
Buy a valve cover gasket and then pull-off the valve cover and adjust the valve lash.
The SL6 offered in 1970 has adjustable (mechanical) lifters / lash and those need occasional adjustment.
