It is currently Tue Jun 16, 2026 3:58 am
 Post subject: ngk spark plug
PostPosted: Wed Aug 04, 2010 1:41 pm
are we sure that there is no interference with this long plug?
PostPosted: Wed Aug 04, 2010 1:55 pm
Not sure which NGK's your referring to.....
I use the NGK UR4GP/#2869 spark plugs in my 78 peanut plug head with no problems. Click on the red link below my name for pictures of the plugs after 55,000 plus miles.
PostPosted: Wed Aug 04, 2010 4:11 pm
I use R5672A-10. no issues.
11.02 @ 120.56
Chassis dyno
 Post subject: Re: ngk spark plug
PostPosted: Wed Aug 04, 2010 5:08 pm
Dozens of people with 225s have had zero problems with spark plug to piston interference with the extended tip NGK plugs.
 Post subject: ngkzfr5n
PostPosted: Wed Aug 04, 2010 5:56 pm
I am looking at a NGK zfr5n plug for my 73 225. Are we sure there is no interference? My parts guy is calling me nuts!!!!!!!!!!!!!!
PostPosted: Wed Aug 04, 2010 6:03 pm
As long as you aren't running zero deck it shouldn't be a problem.
Is your engine modified? Stock the pistons will be down the hole .140 to .180"
Lots of room. Gobs.
The ZFR5N works great up to 8.5 or 9:1. Beyond that, it isn't a clearance issue, but a heat range issue. With 10.7:1 I run ZFR6-FIX-11 Iridiums, though they are not extended reach.
As your compression exceeds 9.5:1 go colder. :D
 Post subject: thanks
PostPosted: Wed Aug 04, 2010 6:25 pm
AS ALWAYS........thanks to everyone!
 Post subject: Re: ngkzfr5n
PostPosted: Wed Aug 04, 2010 6:26 pm
Has your parts guy ever torn down a 225?
PostPosted: Wed Aug 04, 2010 9:16 pm
I just put them in my 225 a few weeks ago and no problems.
DRIVE IT,DON'T HIDE IT
