It is currently Sat Nov 21, 2026 3:22 am
PostPosted: Tue Aug 10, 2010 11:30 pm
What size threads are the test ports for the various pressure tests on the transmission case?
FSM only mentions the mopar tool to use, not a generic equivalent.
PostPosted: Wed Aug 11, 2010 12:35 am
The ports on the trans case look to be 1/8"-NPT.
PostPosted: Wed Aug 11, 2010 8:35 am
Be sure to use a pressure gauge that reads high enough, some of the test pressures are in the 200 to 300 psi range.
