It is currently Wed Apr 29, 2026 3:17 am
 Post subject: 3;91
PostPosted: Wed Jul 23, 2003 8:13 pm
can i put an 8 and 3/4 with 3:91 gears from a 73 duster into my 70 dart slant six with a 904 and stock drive shaft
until i get my 340 built
PostPosted: Wed Jul 23, 2003 10:52 pm
the rear end will be a direct swapp, however the driveshaft will have to be shorten'd and also have a conversion u-joint installed in the rear of it...
jeeze "until i get my 340 built", what a.... ohh i'll stop ranting now :roll: :roll: :roll:
PostPosted: Wed Jul 23, 2003 11:14 pm
He'll have to measure up what he needs for the driveline he may need a conversion u-joint, his dart has a longer wheelbase than a Duster, so he might be able to get away with a /6 duster driveline and a u-joint change depending on how the length measures up...
PostPosted: Thu Jul 24, 2003 2:35 pm
Why would he need a "conversion" ujoint? The 7 1/4", 8 1/4", 8 3/4" and 9 1/4" axles all use the same "small" ujoint. The only reason he would need a "conversion" ujoint is if the 8 3/4" axle was from behind a 440 or a truck.
PostPosted: Thu Jul 24, 2003 9:18 pm
A body 340 4 spd cars up to '70 or '71 had the big 7290 joint. Or the 'chunk' may have been changed over the years. A conversion joint may be needed.
Cecil
 Post subject: i really do
PostPosted: Thu Jul 24, 2003 9:38 pm
, thanx, i reallly do have a 340, or half of one any way, just a block
PostPosted: Thu Jul 24, 2003 10:38 pm
...I don't think anyone doubted that you own a 340, I think some people here just wondered why you'd take out that awesome /6 to put in a regular ole' V8... :o
"DW"
If it ain't broke, fix it!
 Post subject: twin turbo
PostPosted: Fri Jul 25, 2003 6:45 pm
if i could find a twin turbo set up that ive seen on the net before i would deffinatly change my mind
PostPosted: Fri Jul 25, 2003 8:58 pm
To change from a 7.25 to an 8.75 you will need to shorten the driveshaft 1.75". (Been there, done that-twice) :shock:
I have 3 8.75 chunks laying around. 2 from 340 auto cars and 1 from a 4-speed 383 Roadrunner. The 2 340 ones have the small yoke and the RR one has a large yoke. :shock:
