It is currently Fri Nov 13, 2026 8:50 pm
 Post subject: Coil wire burned through
PostPosted: Sun Aug 15, 2010 3:06 pm
My 62 Valiant stopped running abruptly this morning. Thought it might be the timing chain so I was going to pull the distributor cap when I saw that the coil wire had just burned in half. Has anybody else ever had this happen? Does it indicate a problem? I had a relatively new Summit wire set on the car probably 4 or 5 years old. I have been running a MSD 6AL for about the same time with a stock coil.
PostPosted: Sun Aug 15, 2010 5:31 pm
6 Pack Dart
My guess is the MSD puts out a lot of current and the extra amperage caused the coil wire to burn. Sort of like too small a fuse in a load line.
Richard
PostPosted: Sun Aug 15, 2010 6:27 pm
If the stock coil is hot when you run it for a while the 6al is a bit too much. Hot coil hot wires. Well you know of what I speak. I did have something simular happen because of an improper ground on the box.
Shouldn't be too hard to sort out if the coil is getting warm.
regards
MaX
1966 barracuda 360
1964 signet conv. 170 turbo
Bonneville or Bust 2012
