It is currently Fri Nov 20, 2026 5:57 pm
PostPosted: Sun Aug 22, 2010 10:11 am
i read somewhere that a small block 904 converter will work on a /6 904?
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
PostPosted: Sun Aug 22, 2010 10:17 am
Yes they will fit, as long as you use a 65-67 V-8 converter on a 60-67 trans, or a 68 up converter on a 68 up trans. The stall speed may or may not be correct, by a couple of hundred rpm. Also a 360 converter would need the weights removed. One other thing a lockup or non lockup converter must be used with the correct lockup or non lockup trans.
PostPosted: Sun Aug 22, 2010 10:23 am
really! cool! so the small blocks have the same deal with the torque converter hubs? and i need a 3K converter so i'll have to find out what the cnverters are rated at...
thx
PostPosted: Sun Aug 22, 2010 2:49 pm
In a stock application the Slant and 318 get the exact same converter.
In the aftermarket, reduce the rated stall for a small block by around 400 RPM for a Slant application as a general rule.
PostPosted: Mon Aug 23, 2010 9:47 pm
running about 220hp and 250tq. 400 rpm difference still a good range?
thx
 Post subject: -
PostPosted: Mon Aug 23, 2010 10:02 pm
I disagree with S/6 and 318 converters being exactly the same one.The 318 one behind a S/6 will stall 200-300 RPMs lower than the OEM S/6 one.I've put quite a few S/6 converters behind 318s for a "free" performance trick,including my daily driver.
