It is currently Fri Nov 20, 2026 8:41 pm
PostPosted: Mon Aug 09, 2010 11:52 pm
Trying to decipher if I have a Suregrip in my truck. This rear-end was swapped into my truck before I bought it. It is not original. it has allegedly 2.76 gears, has a "X" on either side of it with a dot above it and below it and has the numbers stamped on the driver's side that read:
"2070741
25"
Exactly like that... but the "25" is below the "41" I have no idea if that matters. :) oooo also, there is no tag on this thing. These stamped numbers on there are the only markings.
Just trying to make sure... Pun intended.
THANKS GUYS!
-Marc
1965 D100 225 slant 6, NP435 Utiline.
PostPosted: Tue Aug 10, 2010 4:25 am
Jack one rear wheel off ground, place transmission in Neutral, and with parking brake off, try turning the raised wheel by hand. If it turns; you don’t have a Surgrip differential.
Caculate your rearend ratio by this method.
PostPosted: Tue Aug 10, 2010 9:02 am
Cool. That settles it then. I do not have Suregrip. THANKS!!
I will calculate my exact ratio later this morning using that method.
-Marc
PostPosted: Tue Aug 10, 2010 11:19 am
EXCELLENT. It's official... I have a 2.76 rear. lol
THANKS GUYS!! flawless method.
-Marc
PostPosted: Sun Aug 22, 2010 10:37 am
also u have a "741" case
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
PostPosted: Sun Aug 22, 2010 12:21 pm
Sorry to be a noobie... but is that good? Is that important when looking for parts, hauling or doing burnouts? Lol what other cars/trucks used that case? I would to love what vehicle my rear came from.
PostPosted: Sun Aug 22, 2010 2:10 pm
The 741 center section for the 8 3/4 rear ends went form 1965-1974. I believe its pretty popular on most 8 3/4 rears. Can't tell you what its from, but it has to be something 1965-1974 and could be from a car, truck or maybe even a van? I know that the Darts/Valiants could have an optional 8 3/4 which (I think) only came with the 741 pumpkin. So I guess most cars (with 8 3/4 rears) would have had these cases.
As far as how good it is to have a 741, I think most people prefer either the 742 or 489. However having an 8 3/4 is probably plenty more than enough for a slant when it comes to hauling and burnouts. I believe parts are more easily had for the 742 and 489 though.
'66 Dodge Dart
PostPosted: Sun Aug 22, 2010 2:47 pm
I have a 3.91 SG 741 rear that I've hammered in my '66 for ages. The 741 gets a bad rap from those that just have to have a 489 case. I think it's fine. :D
