It is currently Tue May 12, 2026 6:56 pm
 Post subject: fuel smell inside car
PostPosted: Tue Aug 24, 2010 6:22 pm
When I buy gas I get a very strong gas smell inside the car. I don't smell anything outside or under the hood. Maybe a little in the trunk but mostly inside the passenger compartment.
Car is a 1975 Valiant. I've owned the car for a long time but only recently fixed it enough to drive on a daily basis.
Any suggestions?
PostPosted: Tue Aug 24, 2010 6:46 pm
Site Admin
The fuel fill pipe enters the trunk area, and goes through a seal in the tank. There is also a rubber boot that seals the fill pipe to trunk floor junction. If you have holes in your floor, it's possible you are getting gas fumes from any leaky components there.
The '75 has a charcoal canister on the passenger side inner fender in the engine compartment where the vent runs from the fuel tank.
Check the hoses to the charcoal canister for condition, and look for any fuel leaks in the engine compartment.
Your carburetor has a line that goes to the charcoal canister as well. I'm thinking the vent line, purge line, or the canister itself.
That little charcoal canister get's pulled off by folks that think it's some evil Horsepower thief. All it does is keep gas stink away. :lol:
Other possibilities:
There is a rubber seal behind the sending unit that seals it to the tank. If you pull the sending unit and find the seal is damaged, you should be able to get a new one. Use vaseline or something similar to lubricate it for assembly.
If someone installed an early fill tube with a vent, that may be the source of the smell. Early fill tubes had a vent tube that vents the tank back to the gas cap area of the tube inside the trunk.
That gives you a little bit to work with. :D
CJ
 Post subject: -
PostPosted: Tue Aug 24, 2010 10:05 pm
The vapor return line could be rusted out,and leaking fuel if you have a full tank. My '79 volare' did this,when I would stop,or go around tight corners when the tank was full. It took me a while to find the problem,as when I got home,and looked it it,everything was dry,but I could smell fuel while driving.The top of your fuel tank could be rusted out also.
