It is currently Sat Jun 13, 2026 4:04 pm
PostPosted: Wed Aug 25, 2010 1:44 pm
ok me and my dad had the engine rebuilt and put it in and it cranks but wont start? the ignition coil gets power, the distributor has spark, is there sumthing else? a special way for timing? we just lined up the notchs to "0" and set it to the first piston n made sure it was up top. we need help =(
PostPosted: Wed Aug 25, 2010 1:59 pm
PostPosted: Wed Aug 25, 2010 3:20 pm
did you time it on TDC compression? it could be as simple as leaving out the distributor rotor. check the carb for fuel, look down the top and hit the gas pedal if it sprays fuel its probably ok. to check the ignition system grab a propane or map pipe torch, take off the end to get more flow, stick it in the top of the carb while covering the carb with your hand a little and try to fire her up. you can get the mixture right by moving your hand around.
PostPosted: Wed Aug 25, 2010 3:54 pm
Sounds to me like the timing is off, may-be the distributor is not positioned correctly and/or the timing mark on the damper is not right.
Pull the #1 sparkplug and find TDC by feeling for the #1 piston, as it changes direction. Try to find 10 degrees *before* TDC.
Now loosen the distributor and take a sparkplug and stick it in the end of the plug wire and ground it to the head or block.
Turn-on the ignition (or connect the hot wire) and rotate the distributor while you watch for a spark at the grounded plug tip.
Snap, when you cross a place where the plug fires, you will see the spark jump the plug gap. Go back and forth with the distributor....snap-snap-snap, you will find the exact place to lock down the distributor, (right when the plug fires) again, the engine should be positioned 5-10 degrees BTDC.
Try to fire the engine up and recheck the timing, with a timing light once it runs.
PostPosted: Wed Aug 25, 2010 5:21 pm
ok yea we put the #1 piston TDC but i'll double check everything again. n e other help is welcomed, thank u guys
PostPosted: Wed Aug 25, 2010 6:17 pm
If you had #1 at tdc and aligned the dots on the timing gears, and then put the distributer in for #1, you are 180 degrees off with the ign timing. When the dots are aligned it is #6 that is at tdc compression, and #1 is at TDC exhaust.
PostPosted: Wed Aug 25, 2010 8:09 pm
I am matching up the lines on the pully and the timing thing with the numbers and notches. Am i doing sumthing wrong
PostPosted: Thu Aug 26, 2010 5:00 am
Not really, but the line on the pully and the timing tab, will line up with number 1 at TDC compression (this is what you want) and also number 1 at TDC exhaust.
PostPosted: Thu Aug 26, 2010 7:36 am
So then wen i do this, i shud line up the distributor to #6? I tried 1&6 and it wont start. My pully had two notches on it
PostPosted: Thu Aug 26, 2010 8:41 am
Maybe it has the wrong year balancer on it or the outer ring (pulley) may have slipped pull #1 plug put your finger over the plug hole and have someone else bar the engine over till you feel air pressure escaping around your finger keep going till the air stops then see if the timing mark is close to the TDC mark on your timing tab
Brian
63 Plymouth Valiant Wagon
PostPosted: Thu Aug 26, 2010 10:00 am
Brian
im very new to this lol im only 19, so n e ways so pull out the spark plug and place my finger over the hole? and by bar u dnt mean crank correct? is my finger suppose to have a tight seal on it? oh yea, i guess it has a engine from a 1980 volare.
PostPosted: Thu Aug 26, 2010 3:39 pm
i might be on this forum for a while lol i dnt think my dads gonna wanna get rid of this car, not now lol
photos of the car
http://www.slantsix.org/forum/viewtopic ... 637#288637
PostPosted: Thu Aug 26, 2010 11:32 pm
cranking it for the first time, fuel pump not working
http://www.youtube.com/watch?v=tEjW44CVooE
PostPosted: Mon Aug 30, 2010 12:34 am
thanks everyone, we're still having motor problems, if any one has the timing for 1980 volare 225ci please let me know, from the cam gear to distributor. every bit of information may help, ive also put up a video of the car cranking, its post above in my above comment, thanks
Users browsing this forum: Amazon [Bot] and 4 guests
