It is currently Fri Jun 19, 2026 1:36 pm
Post new topic  Reply to topic  [ 26 posts ]  Go to page Previous 1 2
PostPosted: Wed Sep 01, 2010 2:38 pm
This is done with liquid measured out into the sealed cavity to get exact CC on each combustion chamber and piston tops.
BTW. that piston tops I see looks like those pistons were for turbo 2.2 or turbo 2.5.
Cheers, Wizard
 Post subject: What the heck?
PostPosted: Wed Sep 01, 2010 8:46 pm
What's the part number on that head?
I don't think I've seen one with the open cooling passages on the deck side...
 Post subject: Re: What the heck?
PostPosted: Wed Sep 01, 2010 10:51 pm
well I really do not know that and it is currently at the work shop. But I can learn it on saturday and try to inform you. As I said before, it is cast steel head, it is impossible to replace valve seats, they are cast too!!
PostPosted: Thu Sep 02, 2010 1:25 am
That's an '81-up hydraulic head. I think they're all like that.
That 13cc dish is really killing you.
PostPosted: Thu Sep 02, 2010 2:43 am
Yes and today I have found no-dish pistons, I will buy them and install. Also try to achieve 48 cc Combustion Chamber volume to get 9:1 CR. I guess this engine is built for 70s turkish market... the petrol quality was horrible. I can understand why chrysler preferred low comp pistons... I hope my valves does not hit to the pistons... In the end I need to shave 0,09" just to get 9:1.. I guess there will be night and day differance in performance... :)
PostPosted: Thu Sep 02, 2010 7:35 am
Your valves will not even get close to the pistons. Sounds like a plan...
PostPosted: Thu Sep 02, 2010 9:53 pm
getting from 8.4:1 to 9:1 does not seem much but from 7.4:1 to 9:1 seems quite a lot. Do you think there may be reliablity issues? Normally the head and rest should be as strong for 9:1... (I hope :shock: )
 Post subject: Yep.
PostPosted: Thu Sep 02, 2010 10:20 pm
As long as you are shooting for 9:1 it should not be an issue, but if the bores are worn and the rings are high mileage something may give...
If you were shooting for 10:1 then it'd be a yes...but 9:1 isn't too bad.
You will see night and day difference between 8:1 and 9:1...it get's better if your cam is degreed correctly and you dial in the timing...
 Post subject: Re: Yep.
PostPosted: Thu Sep 02, 2010 11:44 pm
Well, it will be all new rings and pistons so this should not be a problem. I believe that the cam will be ok (I plan no retarding etc) but worried about timing.. if recurve is necessary I am not sure if anyone can do it here... People here dial with recurve if there is pinging.. we'll see
PostPosted: Sat Sep 04, 2010 4:14 pm
My duser is my daily driver and it's running a much bigger cam with 10:1 comp 100 shot with goodies gets me to school work and anything in between
Kev
PostPosted: Mon Sep 06, 2010 10:38 pm
Kev
So not much of a problem than... I feel a little bit worried since it looks I am changing too many things at a time... I wish the pistons were flat... :) Anyhow I will do it and see..
do you have an idea about your HP of your slant? it is not a match for my slant but it will give an idea..
