It is currently Thu Jun 11, 2026 10:28 am
PostPosted: Mon Sep 06, 2010 1:14 am
I recently bought a resorted Carter ball and ball carb for my 65 dart 225. I know it is running rich because at start up I get black condensation out of exhaust pipe which they turns to black smoke when car is warmed. so I know from ere i must adjust the fuel mixture screw but which way richens the fuel and which way leans it?
PostPosted: Mon Sep 06, 2010 2:25 am
Screw in for lean
Screw out for rich
Make sure your choke is working correctly
PostPosted: Mon Sep 06, 2010 8:05 am
The fuel fitting in the the front can't move when attaching the line to it. It will change the float height
PostPosted: Mon Sep 06, 2010 8:48 am
I think my choke works...sometimes. i tested the thermostat spring In hot/cold water and it tightened and loosened it the correct directions but I think it would be better to buy a electric choke. does anyone know where to find these?
oh and another question. what does the thermostat on my exhaust manifold do because I think that may not be working as well.
PostPosted: Mon Sep 06, 2010 11:56 am
you mean the choke thermostat? when its cold it closes your choke and as it warms up it will open it back up.
PostPosted: Mon Sep 06, 2010 12:10 pm
no it's seems like there is s thermostat underneath the carb on the exhaust manifold.
PostPosted: Mon Sep 06, 2010 12:54 pm
make sure its free moving somebody correct me if i'm wrong but it closes the exhaust when cold to warm it up faster then opens the exhaust up to flow freely when warm.
PostPosted: Wed Sep 08, 2010 8:39 am
Hi gnome, and welcome to the forum. You should start by going to the 'sticky' FAQ in the 'engine' section, there are many links on carbs, and you will certainly find some refs. to your questions there.
There are many posts on the chokes and the best adjustments and modifications, use the search function and make a search for 'choke' and you'll get more than 3000 hits, try 'electric AND choke', and you'll get some 600 hits, then you can refine it from there with your carb type or other parameters. All red text are clickable links.
Olaf
Aspenized
PostPosted: Wed Sep 08, 2010 9:28 pm
Olaf
good info, but it wasnt my question...it was eppy25's :)
PostPosted: Thu Sep 09, 2010 8:36 am
Sorry gnome and eppy25, a small window on an ancient screen made me look to low in the thread to see the original owner!
Olaf
Aspenized
Users browsing this forum: Ahrefs [Bot], Amazon [Bot] and 3 guests
