It is currently Wed Nov 18, 2026 12:34 pm
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
PostPosted: Wed Sep 08, 2010 7:38 pm
You can get a complete 8" center section with everything new (incl truetrac) but the case and the yoke for $1000. It's $800 for a new trac loc ltd slip (clutch type).
Seems like just buying a suregrip for you 8.25" axle would be by far easier and cheaper. You can likely buy with new bearings pressed on and install it yourself - no need to remove pinion and only need to set backlash+side bearing preload when you're done.
Thanks for all the tips Lou. I figured if anybody knew about this it would be you. Would that be from the dealer, or aftermarket?
Sam
PostPosted: Thu Sep 09, 2010 5:11 am
Look at Ebay and Mopar shops like manciniracing.com for the 8.25 SG. Rick Covalt had an idea of where Ryan got his??
PostPosted: Thu Sep 09, 2010 5:28 am
Ryan says that guy is not posting his ad any longer. I have some idea where to start looking when if and when I want to do this now.
Sam
