It is currently Thu May 14, 2026 2:31 pm
PostPosted: Mon Sep 13, 2010 7:48 am
I can't find 'em fellas...help!
PostPosted: Mon Sep 13, 2010 8:59 am
Stock location is just in front of the lower rim of the dash, just to the right (left - brain fart?) of the steering column. Reach your arm along (and down) the steering column until your hand is under the dash, then raise your hand (relative to the Earth) and you will touch it. Someone may have moved/removed it??
PostPosted: Mon Sep 13, 2010 11:08 am
Amazing what a lil' 'upper level' guidance will do. Found it!
