It is currently Fri May 22, 2026 11:18 pm
 Post subject: hardened valve seats
PostPosted: Sun Sep 19, 2010 6:44 am
last year i had to remove the head because the hardened valve seat on 4e had come loose, bouncing on the valve like a ring on a string. no damage was done :shock: a local shop was able to reseat it and peen it back in, i asked them to check the rest when they had it. now 1e has come loose :cry: same rattling sound, same pre tear down inspection. the valve stem wont come up fully, stays down about 1/4". so...whats causing this? and whats the fix? weld them in? more peeinig?
71 valiant 225, 904, 7 1/4
69 W200 power wagon 318, np435, np205, d44 front, d60 rear
PostPosted: Sun Sep 19, 2010 10:07 am
The cause is that the seats don't have the proper interference fit. The fix is to use a machinist that should actually be a machinist. If the head has to be peened to retain the seat then the seat is not tight enough in the head and the valve and seat will run hot.
PostPosted: Mon Sep 20, 2010 9:15 am
The good news is that valve seats come in different OD sizes so you should be able to find a larger size insert and re-do the job, using the correct interferance fit.
PostPosted: Thu Sep 23, 2010 12:56 pm
thanks guys for your replies. after talking to a good head shop (Heads by Rick) i may be better off by starting with a new head. will take it out to him tomorrow and let him check it out.
HBR builds racing engines and seems to have a good reputation.i walked into the back of his shop and stood next to his dragster while he made a pull on his engine dyno (the ground shook). then he called me in and we talked about my slant six.
Users browsing this forum: Amazon [Bot], Google [Bot] and 11 guests
