It is currently Tue Nov 24, 2026 5:53 pm
PostPosted: Sat Sep 18, 2010 11:18 am
Hi everyone!
I have a 65 Dodge A-100 scooby doo van which has a slant six 170 I think, I found watery oil on the ground and I assume I have a cracked block.
If I am going to replace the motor what options are available, I thought the 170 was a lower profile to fit the engine compartment?
In any case can I choose any 225 slant six up to the 70's. Please let me know your thoughts, the van is in MExico and I will be doing the work there and likely find whatever parts there too. Thanks!
PostPosted: Sat Sep 18, 2010 3:07 pm
It's highly doubtful they put a 170 in a van, but you can check by looking at the stamp on the top of the block. It is beneath the #1 spark plug under the head. There is a shelf that, when cleaned off, will have some digits stamped there. Post what you find, or a photo of the front of the block if you can get it. With a good photo many of us can ID a 170 right off.
"Watery" Oil on the ground is not necessarily a bad block. Where is it coming from? Park it over a piece of cardboard and identify the area of the engine the oil is dripping from.
Is the dip stick coming out with milky looking oil on the tip? A bit of milky oil up toward the top of the stick can happen when it's wet out, or high humidity is present and the engine isn't fully warmed up when running.
Be great to see a photo of your Scooby Van! :D
PostPosted: Sat Sep 18, 2010 7:35 pm
Car Model: 65 A100 truck
Both the 170 and 225 were available in A-100's .what trans does it have ?Crank register size is different starting 1968. Other then the 225 being taller than a 170, any slant six will fit the A100 engine compartment.
PostPosted: Sat Sep 18, 2010 8:00 pm
Hello and welcome! 170 and 225 motors were available in the A-100s.
However, please, please, please, please, please, please, please, please, no more "scooby-doo" references. Vanners have been working hard for years to dispel the stigma of "Scooby-Doo" that has been cast upon vans. See www.vannin.com
PostPosted: Sun Sep 19, 2010 1:04 pm
Thanks for the replies, it seems pretty well confirmed that it is a 170cu so I am wondering if there is anyone with knowledge or experience if its possible to replace it with any other 225 from a later model duster for example? I have custom dual headers and most other parts besides the motor is new.
I am wondering is the 225 much taller than the 170 and would there be space height wise to fit, I recall the 170 was lower height.
Again, I do not know how serious the issue is, but I did find a pool of watery oil and it was running consistently hot so I imagine the block is cracked. I recall having hit a puddle which may have splashed the motor when it was very hot, It happened as I stopped the car and the oil was only noticed much later, it hasn't been driven since. So there is no heavy cylinder wear with water though I am not use how to know for sure or what approach is best to move forward. I do have excellent mechanics and parts just not sure which is the best path? Any ideas would be appreciated. I could get another block and go from there?
PostPosted: Sun Sep 19, 2010 2:02 pm
Diagnose the problem first! Begin by thoroughly cleaning the engime with "GUNK Engine Brite" or similar degreaser. Then look for coolant leaks at gaskets, hoses, water pump shaft seal weep hole, and core plugs (there are several in both the block and head). A new core plug may require removing the engine, depending which one it is, but its a $1.00 part. If a core plug is leaking, the others are not far behind. Replace all of them, particularly if you pull the engine. Look for oil leaks at the crankshaft front and rear seals, gaskets, oil pump/filter, pan gasket, drain plug (use a new drain plug gasket every time you remove the plug), spark plug tubes, and valve cover gasket. If you're leaking coolant into the crankcase, the coolant level in the radiator will fall and the fluid level in the crankcase will rise; the oil will also become a creamy light brown color. You can also send an oil sample to Blackstone for analysis (~$30). If pressurized oil is leaking into the coolant, there will be oil visible in the radiator. If you can't locate the problem, examine the engine with an ultraviolet light. Antifreeze may flouresce on its own, otherwise add an ultraviolet dye. Then add some ultraviolet dye to the crankcase and drive it a while. Again check with UV light to find any oil leaks. Leaking crankshaft seals are common on high-mileage engines. Remember a miniscule amount of oil will always weep past a shaft seal.
Don't try to solve a problem by replacing good parts with new parts; its a waste of time and money, and usually doesn't solve the problem.
Ken
I have the three speed manual, which is a three on the tree. the transmission is in good shape as I have replaced some of the gears and maintained it well. hmm so I am limited to 225s up to 1968? or I need to change transmission? argh
PostPosted: Sun Sep 19, 2010 2:06 pm
Ken
Thanks this is good information. I can remove the motor covers get a good look but I think its a good idea to remove the motor and begin to take a good look.
PostPosted: Sun Sep 19, 2010 2:32 pm
A new core plug may require removing the engine, depending which one it is, but its a $1.00 part. If a core plug is leaking, the others are not far behind. Replace all of them, particularly if you pull the engine. Look for oil leaks at the crankshaft front and rear seals, gaskets...
Any suggestions where I can buy these parts?
PostPosted: Sun Sep 19, 2010 3:29 pm
Wow! Nice van, and the 8-door models are very rare!
In all honesty, you will be happier in the long run if you pull the 170 and put in a 225. The 170 is just too tiny of a motor for that unaerodynamic brick of a vehicle. However, if you want to try and fix the 170, FREEZE PLUGS HERE, and you can buy a complete gasket set at most auto parts stores.
PostPosted: Sun Sep 19, 2010 3:34 pm
You can still use the same trans, only the flywheel has to be replaced in order to use a 68 on up 225.
PostPosted: Sun Sep 19, 2010 6:28 pm
Any auto parts store will have them. Core plugs are sized by diameter and depth; there are shallow and deep styles available in each diameter. Use the same as you remove from the engine. Use steel plugs. Brass plugs will cause galvanic corrosion of the block in the area near the plug, particularly if your antifreeze is deteriorated. (Checking the pH of the coolant will give you a general idea of its condition. The pH should be well above 7.0) Coat the plug and the bore with a gasket sealer before driving it in. In an emergency an expanding rubber plug can be used on a temporary basis. If you use rubber, I also recommend either using a low-pressure radiator cap (~4psi), or else leaving the radiator cap turned to the safety detent so that there's no pressure in the cooling system.
If you want to order online, there's
www.rockauto.com (I highly recommend them)
www.napaonline.com
www.advanceautoparts.com
www.autozone.com
www.oreillyautoparts.com
www.kragen.com
and others...
btw core plugs are often incorrectly referred to as "freeze plugs". They do not prevent freeze damage. Their *only* purpose is to plug the holes through which the casting sand from the core was removed.
Ken
PostPosted: Sun Sep 19, 2010 6:42 pm
Thanks I am looking for documentation on where the core plug is located and what steps to replace along with gaskets. I have manuals but they are pretty basic.
Not sure it helps, but prior to the oil leak, I was going to store the van and had drained gas, I had to move it so I used the starter motor to drive it about twenty feet in gear and then I noticed the watery oil on the ground as well I check the oil stick and it was a little watery. Prior to that I had been running hot and I had worked on the problem for some time without much luck I usually only drive it around town for about 20 minutes at most.
PostPosted: Sun Sep 19, 2010 7:00 pm
You should have the Factory Service Manual for the vehicle. There's another thread on this site that explains how to use a Haynes/Chilton/Motor repair manual. LOL! (Does anyone have the link?)
The FSM is available on CD from www.moparmanuals.com (Dave Waller, a Mopar Mailing List member).
If you prefer hardcopy, www.autobooksbishko.com has them
Look on the side of the engine block below the manifolds. Depending on the year of the block, there will be either 3 or 5 core plugs. These are the ones in plain view; there are others that are difficult to reach/see unless the engine is removed from the vehicle..
Ken
PostPosted: Tue Sep 21, 2010 4:16 pm
Hi everyone
Just wondering if anyone had any other ideas of what could be wrong and be checked out on my slant 6 in my dogde 65 A-100 van (besides everything), the motor has watery oil in it and watery oil is leaking on the ground.
I will be taking the motor out to check it out but would appreciate any suggested issues besides visible cracks in the motor case?
I wll be removing the motor and proceeding in the coming week.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 4 guests
