It is currently Sat May 23, 2026 10:26 am
PostPosted: Mon Sep 20, 2010 7:46 pm
I guess the basic question I have at this point is what other cars, van or trucks can I salvage the parts from. there are no darts in the junkyards here so I'm thinking a Volare, a Diplomat, a Cordoba (maybe) or a van or truck from the same era. Am I correct. Are there others I'm not thinking about. The most important thing seems to be the spindle. Most of the rest of the stuff can still be purchased new but is cheaper at the junkyard. Am I correct. thanks for any info......vic :D
PostPosted: Mon Sep 20, 2010 8:02 pm
What brakes do you have now? If you have 10" drums you can keep your existing upper control arms. If not you'll need upper control arms from a '73 and newer A-body. The spindles can come from a '73-'74 E-body, a '73-'76 A-body or any F-M-J body car like a Diplomat, LeBaron, 5th Ave, Volare or Aspen. No trucks or vans need apply.
PostPosted: Mon Sep 20, 2010 9:50 pm
Any B body, R body, E body or FMJ body brake system will bolt on to a '74 A body. The best system to use is the 1976 or newer 11.75 setup but you'll need 15 inch rims to clear the big rotors. The 11.75 rotors only came on the late model B body and R body cars.
 Post subject: 74 dart
PostPosted: Tue Sep 21, 2010 7:42 am
thanks for the info fellows...just to be clear does disc brake setup on all lebarons work or is it just the earlier models (which I read somewhere) Hope its all of them as there are many of them at the pullaparts here.........thanks
PostPosted: Tue Sep 21, 2010 8:30 am
Only the rear wheel drive LeBarons are suitable donors.
