It is currently Sat Jul 18, 2026 9:48 am
Post new topic  Reply to topic  [ 49 posts ]  Go to page Previous 1 2 3 4
 Post subject: Re: Reply??
PostPosted: Sun May 24, 2009 3:40 pm
Charlie did you ever get a reply back on this seat belt issue. Racing belts "upgrade" obviously seems to be safer than a 40 year old set of OEM belts!
Rick
Actually, NO. I had forgotten about this. I never got a reply back. At my local track (Gainesville Raceway) The tech inspector requires that my "racing" belt be within the dates range. Which mine are, for now.
PostPosted: Wed May 27, 2009 6:07 pm
One other thing tech guys require at sometracks anyway is a driveshaft loop if you run a slick reguardless of ET.
joesnow AKA Dan
PostPosted: Wed Sep 22, 2010 5:28 am
Updating this old thread. I never did hear back from NHRA about the seatbelt date issue. BUT:
I was reading the 2010 NHRA rule book, looking for something else, and found on Pg 20.37 "general regulations", 10:5 "Driver restraint systems".
"in cases where the class does not require a SFI 16.1 driver restraint system, the two year recertification does not apply".
So most of us can run a "racing" belt, that is more then two years old. (basically, as long as we don't have to run a roll bar or cage)
Many part time racers do not carry a rule book with them, so I listed the reference page/section of the rule book, so if a tech inspector questions an "out dated" belt you can point it out in his book. I would suggest keeping this info in the car.
PostPosted: Fri Sep 24, 2010 3:39 pm
your the man charrlie !!! Great info as always,
-Mike
I am the Guardian, I hate helos, everything leaks.......
