It is currently Fri May 22, 2026 1:54 pm
PostPosted: Tue Sep 21, 2010 11:00 pm
idles fine, but when I hit the gas it chokes, bogs and stalls unless I floor it but then it is slow. Was running fine until I didnt drive it a couple of weeks ago. Im gonna pickup a new fuel filter, any other suggestions? I've seen similar issues where it was the fuel pump but it seems like something is clogged.
74 dodge D100, 1bbl, 225 /6
PostPosted: Wed Sep 22, 2010 6:20 am
It could be a bad accelerator pump.
How long has it been since the carburetor was rebuilt?
1954 Ford, Tudor Mainline
1976 Plymouth Valiant, 4 door
www.automotive-ninja.com
PostPosted: Wed Sep 22, 2010 11:39 am
Not sure when/if its been rebuilt, I've had it just over 2 years. was running and idling fine until recently.
PostPosted: Wed Sep 22, 2010 11:50 am
Could be the gas evaporated out of the carb causing the accelerator pump cup to shrink, leading to a loss of pumping ability.
PostPosted: Wed Sep 22, 2010 1:23 pm
Check for any vaccum leaks or loose/deteriorated hoses.
As for the carb...it's not terribly difficult to take it apart to the extent that you can check the condition of the accelerator pump, however a quicker, but less accurate check is the remove the air filter, and look down the throat of the carb as you manually work on the throttle. If you see a nice, steady stream of gas shooting into the carburetor, then chances are the accelerator pump is ok.
PostPosted: Fri Sep 24, 2010 9:10 am
The issue was a stuck choke plate. I started it and the same thing wouldnt idle, it would stall. Opened the air filter and made sure that the carb was squirting gas fine, I had to open the choke plate to check, once i started it again it was running fine.
Thank you all...Have a great weekend.
