It is currently Tue Nov 24, 2026 8:23 pm
PostPosted: Mon Sep 27, 2010 3:51 am
I have a seized slant that I want to rebuild should a stear away or take the risk, its for a mild build. It has 2 pistons rusty but has a standard bore.
A.D
PostPosted: Mon Sep 27, 2010 4:03 am
If you can get it apart, and the block is not cracked, a machine shop can clean up the bores etc., and your off and running. All the other parts you would need are off the shelf items.
PostPosted: Mon Sep 27, 2010 5:51 am
If you are going to rebuild it right with new pistons etc. then I would use it in a heartbeat, as stated before.. if you can get it apart.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Mon Sep 27, 2010 3:07 pm
Thanks, yeah I rekon I'll be able to get it apart.
PostPosted: Mon Sep 27, 2010 5:33 pm
I had that problem also. I finally got it apart but had to sleeve one cylinder. I'm using a 2.2 liter piston with a .080 clean up bore . Works great. If it wasn't for the expense I would sleeve every cylinder.
Cheers
MaX
PostPosted: Mon Sep 27, 2010 7:21 pm
Car Model: 69 Valiant 225, 70 with a 265, 70 with a 318
Any tips on getting a rusted up slant apart without destroying it?
Richard (aka Fingers)
 Post subject: Lol...
PostPosted: Mon Sep 27, 2010 7:37 pm
If the bottom end sat in water, i think it'd be a boat anchor...
If only the pistons are rusted in the bores...Regular Coke is my favorite
'deruster'....
:roll:
-d.Idiot
PostPosted: Mon Sep 27, 2010 8:04 pm
6 Pack Dart
Would that be diet or regular coke?? :lol:
Richard
PostPosted: Mon Sep 27, 2010 8:08 pm
Richard
Don't think it matters.......
But Mentos can be added to diet coke......
PostPosted: Mon Sep 27, 2010 8:45 pm
Has anyone tried PB Blaster for freeing pistons?? (Just asking...)
 Post subject: -
On a mystery engine,I drain out the coolant left in the block,and check it's freeze point.Then decide if the block could have froze in the 10+ years it probly sat.
PostPosted: Mon Sep 27, 2010 8:47 pm
Only on slant six dot org. Lol*
PostPosted: Mon Sep 27, 2010 9:50 pm
On blast works well Just keep spraying every day. Sometimes you have to remove the crank to knock the piston(s)out
.good luck but it will work with patients and a good brass drift... hope this helps & best regards. Max
 Post subject: Re: -
PostPosted: Tue Sep 28, 2010 1:12 am
No chance of freezing here.
PostPosted: Tue Sep 28, 2010 5:29 am
When I took general science in high school we had to check for pH of different substances..."classic" coke weighed in at a pH of 4, and diet Coke
was 5....nothing like a good can of caffeinated blend of citric, carbonic, and phosphoric acids to restore vigor and tear down those stomach linings...
Users browsing this forum: Bing [Bot], Plymouth_Ruster and 7 guests
