It is currently Tue Nov 24, 2026 11:17 pm
Post new topic  Reply to topic  [ 24 posts ]  Go to page Previous 1 2
 Post subject: Re: Lol...
PostPosted: Tue Sep 28, 2010 6:53 am
"classic" coke weighed in at a pH of 4, and diet Coke
was 5... -D.Idiot
That means 'classic' is more acidic, right? Been a while since Chem.
PostPosted: Tue Sep 28, 2010 8:13 am
Lower pH is more acidic, yes. Your stomach is around pH 2, IIRC, so 100X more acidic than Coke (more H+ concentration).
PostPosted: Tue Sep 28, 2010 10:08 am
I tired a mix of 50/50 mystery oil and kerosene on a frozen engine w/o luck; ended up using a piece of heavy exhaust tube and a sledge hammer to break the pistons to pieces and that worked quite well.
PostPosted: Tue Sep 28, 2010 11:14 am
I have faced many stuck engines in my tractor restoration days. What worked best on these is to pour a little gasoline and diesel mixture in the cylinders, one at a time, and set it alight. It helps if the engine is out of the vehicle and away from anything flammable. Do this process several times in each cylinder. The heating/cooling process will break the corrosion bond between the dissimilar metals. I have also had to use a floor jack to push the pistons up into the bore.
Be careful hammering down on a stuck piston. If more than one piston is stuck, you can damage a rod, crank, or block trying to force the other stuck one up. I always unbolt the connecting rod from the crank and hammer up. If all else fails, just grind the piston away inside the bore. It will need replacing anyways.
The biggest problem will be with the aluminum piston corroding and expanding in the bore, and cracking the cylinder wall.
Ask me how I know.......
Restoring Wife's Great Grandparent's 1963 Dart.
Built August 30, 1962 in St Louis
First month of production
Serial Number 599
Still is a basket case.
PostPosted: Thu Sep 30, 2010 11:08 pm
Thanks everyone for your help, now to get the block crack tested!
PostPosted: Sun Oct 03, 2010 12:10 pm
If you know what cylinder is seized, loosen valves 'til cylinder is shut in, fill cylinder w/ water, hammer ceramic out of spark plug, weld in a zerk grease fitting in said spark plug, put plug in head, pump in grease 'til piston pops free. Believe it or not, this method worked for me on a 10 year out in the field with no spark plug motorcycle engine!
Probably won't work on your particular slant.
Good luck
Dan
PostPosted: Sun Oct 03, 2010 12:37 pm
If the piston is aluminum, caustic soda will work well. There'll be no piston left to unstick!
PostPosted: Mon Oct 04, 2010 2:36 pm
Maybe, but I am NOT barfing in the bores of the next engine I need unstuck ;-p
Seriously, lots of penetrating oil, (ATF makes a good penetrating oil to use in large quantities, IMO) ream away any ridge, and try to extract the piston out the normal way (upward) if you can. Taper from wear is working with you going that way. The downside is that you don't have a very good target to tap on to get things moving.
If that doesn't work, a wooden dowel and a hammer to tap the piston down toward the crank may get things moving, and then you might be able to reverse directions and still go out the top deck. Or go out the bottom if the crank is already pulled. Be patient- things break when pushed too quickly.
PostPosted: Mon Oct 04, 2010 3:32 pm
FYI... Pistons in a SL6 come-out thru the top of the bores, the main bearing "webs" do not allow the pistons to come-out thru the bottom. (in one piece :shock: )
I do agree that it may help to push the pistons down first, to break them loose... then clean any exposed corrosion, re-oil and then attempt to knock them out the top.
