It is currently Sat Nov 21, 2026 1:28 am
PostPosted: Wed Sep 29, 2010 10:46 am
Had a bit of tranny leak from a couple of the bolts being stripped by the previous owner and finally decided to remedy it. So I bought this crappy OEM fix-a-thread tool from Pepboys and tapped 3 threads (the plastic part of the handle stripped while doing this) then when I go to set the insert, part of the tools' tang broke off and is stuck in there. Not sure what to do, I tried removing with tweezers, a couple of needle nose pliers (a bit too big). So now short of buying surgical grade forceps I am not sure what to do, How do you remove the Heli Coil inserts? I would rather not have to drill it out and tap the next bigger size, any suggestions?
BTW: Dont buy any tools from OEM "tools for professionals" everthing but the tapping bit broke.
PostPosted: Wed Sep 29, 2010 10:58 am
I've never had your problem when I used a helicoil; maybe you could use a left-hand-thread screw extractor to back the coil out. I got mine from Sears years ago.
PostPosted: Wed Sep 29, 2010 11:13 am
kbb has the right idea . saw it done that way once...
65 Coronet, 4 bbl, .060 over, mild cam.
66 Valiant, Black, 3spd, Hyperpak, headers.
works in progress...
PostPosted: Wed Sep 29, 2010 1:40 pm
I guess I will be heading to Sears, anyone know the brand name of the tool?
PostPosted: Wed Sep 29, 2010 1:56 pm
True "Heli-coils" are constructed like a wire "spring" so lift-up and grab the end of the first coil, then pull hard... the coil wire should straighten-out & pull right out of the hole.
PostPosted: Sat Oct 16, 2010 10:19 pm
Thanks for sharing.
PostPosted: Mon Oct 18, 2010 1:05 pm
That worked. Thanks all.
