It is currently Fri Nov 20, 2026 12:27 am
 Post subject: window washer junction
PostPosted: Thu Sep 30, 2010 10:13 pm
anyone know the part number or know of a source for the F shaped junction where my window washer line splits at the cowl under the hood to the individual nozzles? if searched parts houses looking for something similar and cant get anything close.
1975 Plymouth Duster,225/6 2bbl. and duels, 904, 7 1/4
1986 Dodge Charger Shelby, 2.2 Turbo I, A525
PostPosted: Fri Oct 01, 2010 5:51 am
Check the “HELPâ€￾ section at Napa where a lot of these obscure items can be found.
You most likely won’t find an “Fâ€￾ fitting, but I believe there are “Yâ€￾ shaped fittings available.
PostPosted: Fri Oct 01, 2010 9:13 am
ACE Hardware also has a very good fittings section.
1954 Ford, Tudor Mainline
1976 Plymouth Valiant, 4 door
www.automotive-ninja.com
PostPosted: Fri Oct 01, 2010 10:15 am
I found them in the cheapie parts store near the PCV valves.
