It is currently Tue Nov 24, 2026 1:31 pm
Post new topic  Reply to topic  [ 57 posts ]  Go to page 1 2 3 4 Next
PostPosted: Fri Oct 01, 2010 5:29 pm
i have been rolling around some plans on an aluminum head for the slant. leaning towards single over head cam but mite make first model run off stock cam.
what qualities would u want in one of these heads. thinking it should have slightly larger than stock ports but fully portable(300cfm?).
so!
what would u want?
2 or 3/4 valves
min/max flow numbers
OHV, single/double cams
deck thickness
shaft rockers, pedestal
valve sizes.
intake to exh location i.e same side or not
combustion chamber dia
what flow numbers max
if i am going to make this i will more than likely have two versions, one is race oriented so combustion chamber will be bigger dia for bigger bores etc, and a more factory style but still lots of room for improvment...
any ideas would be great
thx ed
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
PostPosted: Fri Oct 01, 2010 5:49 pm
all the above
PostPosted: Fri Oct 01, 2010 5:50 pm
all the above
i know right! but i need some specifics. we know a slant head can flow over 200cfm, but how much more to we need? 250, 300?
PostPosted: Fri Oct 01, 2010 6:11 pm
Well people always talk about a cross-flow head.
PostPosted: Fri Oct 01, 2010 6:27 pm
HEMI?????
PostPosted: Fri Oct 01, 2010 6:28 pm
To get really high flow numbers in a 3.4-3.5" bore I think you'll want 4 valves per cylinder. If you model the head off something common like a Neon (3.44" bore) then you already have the valve to rocker geometry, cam position, port and valve sizes all taken care of.
A 3.44" bore 170 is 174 ci and could make 220hp easily while retaining a stock idle. The problem once again is the oil pump drive failing at high engine speeds. Might as well design a cast aluminum timing cover for the cam drive that incorporates a gerotor oil pump ala the Neon. Or maybe just go buy a 2JZ-GE Toyota engine and get it all cheap and easy. Only $650 around here.
PostPosted: Fri Oct 01, 2010 7:07 pm
Don't forget to think about rocker gear... Is there something off the shelf that might work and be affordable at the same time?
11.02 @ 120.56
Chassis dyno
PostPosted: Fri Oct 01, 2010 7:21 pm
Car Model: 1964 Valiant
While you're at it, go ahead and make an alloy block with 3.63" bores, the same diameter as the new stock 5.0 Ford V8, which has a 4 inch bore center. A 3.63" x 4.25" stroke six is 264 inches. A that size you need a better head just to putter around town.
The OEM castings are okay for me. I figure I can turbo the stock head and come out cheaper, if I even want to go that fast. I don't doubt that someone casts new slant heads someday - when I'm 80 years old and gasoline cars are outlawed :)
PostPosted: Fri Oct 01, 2010 10:22 pm
HEMI?????
a must
PostPosted: Fri Oct 01, 2010 10:23 pm
also a must
yea i have been thinking of re scaling a hemi gear to work
PostPosted: Fri Oct 01, 2010 11:46 pm
Yeah, I want a crossflow 4-valve pent-roof hemi wedge twin-spark titanium DOHC full-race street head. I figure I would spend up to $350 if it had all those features.
And a pony. :roll:
PostPosted: Sat Oct 02, 2010 5:47 am
It is unreasonable to expect a pony as well Dan. :tsk:
:lol: :lol:
PostPosted: Sat Oct 02, 2010 6:22 am
Mopar Kid
Ill say this once and then leave it alone. Build What YOU want in a head then market it. Tell us what YOU can do then we either will or wont buy it.
This the problem with asking we cant agree.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sat Oct 02, 2010 7:09 am
240 ponies? :wink:
