It is currently Tue Nov 24, 2026 4:10 pm
Post new topic  Reply to topic  [ 57 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Sat Oct 02, 2010 8:47 pm
but lets face it it can be done, with enough time and money, IT CAN BE DONE, so i say do it, but remember slants are a small tight knit community, there ain't many of us that live and breathe the slant sickness, also keep the price in mind, cheap no says i, thrifty is more like it ;)
But how much your willing to spend will determine how fast you go
-Mike
I am the Guardian, I hate helos, everything leaks.......
PostPosted: Sat Oct 02, 2010 9:04 pm
Will keep my eye out for the check from you Volare4life :) Dont know how to do the smiley face.Mark
PostPosted: Sat Oct 02, 2010 10:06 pm
Car Model: 1964 Valiant
You can mill a "bathtub" from a solid chunk of alloy that includes the deck, valve pockets and ports. A screw on top cover would enclose the water jackets.
The old Jaguar six is the same length as the slant six. I think the BMW must be pretty close. You could maybe use manifolds from a BMW if you wanted to attempt a non stock fancy configuration and use bolt on Pick-n-pull parts. I figure one of these heads is about as far as this might go.
If you mess with the head too much, its not a slant six anymore. Might as well swap in a totally different motor. I like the OEM pushrod head except for needing better ports. Thats why a turbo might just be more practical.
The Fordsix people did a alloy head. I have not followed that project lately. With alloy you need a special head gasket.
PostPosted: Sat Oct 02, 2010 10:20 pm
too easy. see all those "emoticons" on the left when you are typing a reply? select whatever you need from there,click your mouse button on it and it will appear in your post wherever you left the cursor.
regards,Rod :D
PostPosted: Sat Oct 02, 2010 10:40 pm
yep!
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
PostPosted: Sun Oct 03, 2010 4:33 am
FYI-the issues with asking on an open forum about what you should build are simple:
1. You won't get 5 people who all want the same thing.
2. Half the ideas you get will either not work or will cost so much the project can never be cost effective.
3. Half the people giving ideas will never buy one anyway.
4. Most of the people wanting to build an aluminum head have no clue what they are in for.
5. It isn't as easy as it sounds to build a good flowing port for a Slant head. It is easy to toss out big numbers on the Internet, but it may not even work on a mock-up port on a flow bench.
6. 99.9% of the Slants on the planet can't even use as much flow as you can get out of an iron one.
7. See Sandy's post above. :shock:
PostPosted: Sun Oct 03, 2010 6:24 am
or you could just build an alloy head close to factory specs, and be happy with less weight, heat and higher compression :)
Tyler, 19
72 Dart Swinger /6T
PostPosted: Sun Oct 03, 2010 6:46 am
PostPosted: Sun Oct 03, 2010 7:20 am
PostPosted: Sun Oct 03, 2010 8:29 am
Moparkid
your project will be extremely price sensitive.
one way to improve the feasibility of the alloy head project would be to design the head so it is comprised of modular sections.
don't get stuck that it needs to be one six cylinder cast and machined part,, but rather potentially two sets of three cylinder covers or three sets of two cylinder covers. The scale down would be limited by the location and number of cylinder head bolts per bore.
The scale down allows the foundry core process to be simplified,,you will have smaller core tooling that will make more "blows", package will fit into smaller molds,, less gross pour weight per mold,,, exact same effect on machining,, requires smaller fixtures,, CNC tables,,,
The up front tooling cost is the biggest hurdle, this is a way to minimize that expense.
PostPosted: Sun Oct 03, 2010 10:01 am
Dodge considered a Over head cam version of the slant in 1962 but it was never produced. I think it could be done.
64 dart GT /225
...........____ .
...._n_.[____].
.....L\....\......
.......\____\....
PostPosted: Sun Oct 03, 2010 11:41 am
Hats off to creative cheapskates. I think a savvy guy filled with energy and immune to fatigue and defeat can beat a committee design. If it does not work out, you don't have to tell anyone ( except maybe your wife ).
Earl Edgerton's F-head conversion for the small Mopar flathead six reportedly cost $6,500 for his effort, with no clear path to making them cheaper. He has many of the skills needed. He only built two of them. The head looks unique with its 3 valve covers. http://www.moparmagazine.com/assets/ima ... edgy_5.jpg
Jon Winterhalter built a credible Lotus Seven for about $2,000. He spent 80 hours forming the alloy nose cone on an English wheel that he built himself. Then, he built a Ariel Atom clone for $8,000, without ever seeing one. All in his spare time as he worked a day job. Winterhalter said that the knowledge and skills gained were alone worth the effort. You could not take a course for that little and learn as much.
PostPosted: Sun Oct 03, 2010 1:18 pm
build what YOU want.....if you want to build something that will apeal to more peeps....the aluminum head itself will do the trick.I say just a aluminum replacement head, and maybe enough meat to mill it for more compression...how about aquiring one of the heads from Argentina, and reacsting them??
Andrew/kidd
Wife's: 64 Valiant
PostPosted: Sun Oct 03, 2010 2:22 pm
That's the key right there. Build one and convince the rest of us that we need one. It worked for Bill Gates and Steve Jobs. :wink:
PostPosted: Sun Oct 03, 2010 5:30 pm
But I am with Dan, I want a pony with my aluminum head. 8)
Users browsing this forum: No registered users and 16 guests
