It is currently Tue Nov 24, 2026 4:20 pm
Post new topic  Reply to topic  [ 57 posts ]  Go to page Previous 1 2 3 4
PostPosted: Sun Oct 03, 2010 5:48 pm
Build a relatively stock head out of aluminum, with closed combustion chambers and large valves, and you'd have something that might garner some interest.
PostPosted: Sun Oct 03, 2010 7:07 pm
HEMI?????
I would just be happy with an aluminum hemi head. Crossflow would just be a pain in the ass to fit in the bay and to mess with the dizzy and oil filter. And BTW, here we go again.
See Sandy's post above.
'Tis why I say, here we go again.
PostPosted: Sun Oct 03, 2010 7:23 pm
Car Model: 1964 Valiant
Harley only had Davidson. If you do this, surprise us. Then we will cheer!
PostPosted: Sun Oct 03, 2010 9:51 pm
haha ok i can do that!
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
PostPosted: Sun Oct 03, 2010 11:29 pm
I like the idea of getting one of the argentina heads and copying that in aluminum, should be the most cost effective route. Besides, thats a bad a** head and for it to be cast in alloy would be killer :twisted: !! Come to think about it, has anyone brought one of those heads to the states yet and tested it??
To each his own (so what if I wanna build a 450 horse MPFI turbo /6 instead of using a V-8!)
PostPosted: Mon Oct 04, 2010 6:44 am
805kid,
As you can see, this is a "charged" topic. Most of the experienced folks on this board have seen posts like this at least a dozen times, all petering out....
If I were building one for myself:
1) bolt up stock manifolds, valve gear, and valve cover, but raise ports 3/4"
2) 220+ CFM intake (As slantzilla said, most people don't even have a clue what 180 CFM feels like, and 220+CFM is the highest recorded for the highest output motors of 350+ HP.)
3) valves of 1.70-1.78" size range on intake, 1.44-1.52" on exhaust.
4) thick deck and port walls to allow further mods, stock 55-58cc chamber
5) try to design quench/swirl chamber?
If I were building one to sell:
1) bolt up stock manifolds, valve gear, and valve cover, alternator, cooling ports, and MAYBE raise ports 1/4"
2) 200-220 CFM intake (This may be all you can get?)
4) thick deck and port walls to allow further mods, 55-58 cc chamber
We don't want to discourage you, but the number of failed attempts is 100% and in the 10-20 range of fairly serious attempts.
Best wishes,
PostPosted: Mon Oct 04, 2010 6:58 am
or you could just build an alloy head close to factory specs, and be happy with less weight, heat and higher compression :)
Came to say exactly this, leaving satisfied it's been said already.
PostPosted: Mon Oct 04, 2010 12:59 pm
805kid,
Best wishes,
this is what i was looking for! and i know im against alot of odds but as time and money come around progress will be made
PostPosted: Mon Oct 04, 2010 2:10 pm
Go for it! You should have at least one good conversation with Doc about this offline (phone, PM, etc...).
PostPosted: Mon Oct 04, 2010 2:25 pm
And hold out for the pony, too.
PostPosted: Mon Oct 04, 2010 5:23 pm
are we talking like pony as in horse or u guys into miniture ponies? my neighbors got a whole bunch, he won't notice some missing!
PostPosted: Mon Oct 04, 2010 8:53 pm
All i can say is, i wish you luck, and when you are successful, i will be happy to test one for you :wink:
Tyler, 19
72 Dart Swinger /6T
