It is currently Tue Nov 24, 2026 2:41 pm
 Post subject: 727 into my valiant
PostPosted: Sun Sep 26, 2010 9:33 am
is it a lot of messing, i want another gear, thanks
PostPosted: Sun Sep 26, 2010 9:55 am
727s are 3 speeds just like the 904. In fact the 904 is simply a scaled down 727. The valve bodies even interchange. There was even a baby 904 which Mitsubishi used. If you want another gear you're in for a lot of work. Some folks have used the A500 with the adapter originally used to put a small block 727 behind the slant in A100 vans. Others have used the Gear Vendors overdrive. The A500 can be done for less money, but it means pretty major floor surgery. The GV overdrive is generally more money, but it fits better.
PostPosted: Mon Oct 04, 2010 1:10 pm
so it would have to be a overdrive unit
PostPosted: Mon Oct 04, 2010 1:48 pm
You might want to look at a Laycock-De Normanville overdrive unit, such as was used in Volvos. Cheaper than GearVendors, easier to install than GearVendors or the A-500/adapter plate method. The hardest part would be fabricating the mounts for it.
http://www.ntahc.org/techtips/OVERDRIVE1.html
http://www.ford-trucks.com/forums/55557 ... drive.html
http://www.odspares.com/
http://www.classicandperformancecar.com ... rives.html
http://www.vclassics.com/archive/laycock.htm
http://www.buckeyetriumphs.org/technica ... 1/JOD1.htm
http://www.britsportofseattle.com/2010/ ... ipped-car/
http://www.maximum--overdrive.com/
Oh, I see you are in the UK. There should be heaps of these things for you to play with over there. You will have much better luck looking for a Laycock unit than paying for shipping a GearVendors unit or a A500 and adapter plate from the States. In fact, Gearvendors bought out Laycock in 2008, I believe, and now supplies parts for Laycock units.
PostPosted: Mon Oct 04, 2010 2:01 pm
or you can change over to stick shift and an a-833
PostPosted: Mon Oct 04, 2010 6:09 pm
where would you get an adapter to bolt it to a 904?
1975 Plymouth Duster,225/6 2bbl. and duels, 904, 7 1/4
1986 Dodge Charger Shelby, 2.2 Turbo I, A525
PostPosted: Mon Oct 04, 2010 7:37 pm
You wouldn't. You run one dinky driveshaft to the front of the OD unit, then run another driveshaft from the OD unit to the rear axle.
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
