It is currently Mon Nov 23, 2026 9:38 pm
 Post subject: timing chain?
PostPosted: Mon Oct 04, 2010 6:54 pm
ok went to pick up some C-6 trans parts today for work, on the way back as i accelerated onto an on ramp car looses power, stutters, and dies. cranks but wont start.
check for fuel out the carb, and for spark out of the coil and both are present.
guy from work shows up and we give it brakeclean, and check for rotor to tdc mark alignment. seem to be there. flat tow it to work, and since its almost 5 decide to pull plugs, and check for obvious damage. none, but i pop off the cap, and turn the crank 14 degrees according to the timing tab before the rotor moves.
think i jumped a tooth? i noticed the timing moving around by about 8 degrees last time i checked it (less than three weeks ago)
if it did jump are there any off the shelf or mail order timing kits that are roller?
1975 Plymouth Duster,225/6 2bbl. and duels, 904, 7 1/4
1986 Dodge Charger Shelby, 2.2 Turbo I, A525
PostPosted: Mon Oct 04, 2010 8:19 pm
Here is a link to Internal Engine Parts Group
I have two billeted double roller sets from them and they are beautiful but kinda heavy :)
they are $70
I believe the sets are actually made by the new owners of Rollmaster.
http://iep.qwik-order.com/WD/About/about.htm
Tyler, 19
72 Dart Swinger /6T
 Post subject: Yes, but in pieces...
PostPosted: Mon Oct 04, 2010 8:31 pm
If you can't wait for an Aussie Roller or the price is too $$$...you can use the dynagear numbers (you have to order a cam sprocket/crank sprocket, and chain) and cross reference the numbers to SA Gear
 Post subject: -
PostPosted: Mon Oct 04, 2010 9:01 pm
Maybe a badly worn distributor that rode up and jumped a tooth on the cam gear,or deflected far enough away to cause the same.Reset your timing again to factory specs,and see how it runs.If your did jump a tooth on the timing chain,it will run very poorly even with the timing correct.
PostPosted: Mon Oct 04, 2010 11:24 pm
thanks all. i know i dont need a roller timing set, but i like the peace of mind and durability. i was hesitant to think it jumped time at first, mainly because it sounded same as it always has when its cranking: even with a definite chop as each cylinder comes up.
PostPosted: Tue Oct 05, 2010 8:12 am
the chain and crank gear same as big block
PostPosted: Wed Oct 06, 2010 12:33 am
I had the same problem just a few days ago, and I nearly lost my mind setting timing, replacing points, condenser, etc only to remove the valve cover to find 4 out of 6 intake valve rocker pushrods either bent or off their rocker. If the distributor nylon gear checks out, I would pop the valve cover off and check those..and why not check valve lash while youre at it. Let us know what you find :)
The only way you can ever really break something beyond repair is to give up trying to fix it.
PostPosted: Sun Oct 10, 2010 7:32 pm
well finally got around to diggin into it. turns out either my coil failed or my module, which is weird considering i would swear it had spark on the side of the highway.a few months ago i put on a accel coil i picked up at smucks and about two weeks ago i bypassed the ballast, after much debating, head scratching, and testing of various electrical things. swapped box with one on the garage shelf and got no trigger to coil negative, bought new box, and got trigger but no spark, swapped coil and got spark. so problem fixed, ended up using a two wire ballast Napa number ECH ICR23 and module number MPE TP51SB.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot], Google [Bot] and 4 guests
