It is currently Mon Nov 23, 2026 11:35 pm
PostPosted: Tue Oct 05, 2010 4:57 pm
Hey Guys. I Just bought my 1965 Plymouth belvedere II (with the 225 slant six) a few weeks ago, and after driving it around abit, ive noticed a few problems, and was wondering if you guys could help me out.
1. The car is overheating. I replaced the thermostat, thermostat housing, and upper radiator hose. After driving the car around, once I go up a large hill, or a gradual hill, my tempature gauge goes up, sometimes spiking on the H. When I stopped the car and popped the hood, I saw coolant coming out the overflow and it sounded like it was boiling or bubbling. Im kinda thinking its the radiator, so I am going to flush it out and then I am going to replace the lower hose at the same time. I checked the waterpump and its good, and I also ran the car without the thermostat to see if that was the problem, and it was still overheating.
If flushing the radiator doesnt fix it, do you know where I could get an aftermarket replacement? Ive tried everywhere, and either the hose for the bottom is on the wrong side, or it doesnt have a trans cooler..
2. I am getting some sort of massive oil leak. After I drive the car for a long period of time, and I pop the hood, oil is everywhere. On top of the valve cover, on the air cleaner cover, all over the belts, on the bottom of the hood, and even some splatter on the battery etc.. it seems to be pooling up on the lower side of the left of the engine bay, if that helps. I really cant seem to find where its coming from, and its getting EVERYWHERE! Any of you guys expierience this?
Other than that this car runs like an absolute tank. Lots of fun to drive.
Heres a picture of when I got it, and one after I painted it, if anyones interested!
PostPosted: Tue Oct 05, 2010 5:28 pm
Check the lower hose also. If it is soft or the spring coil is rusted away it can collapse and cut off water flow when the engine is running. As far as the oil-how bad is the blow by? Clean off the engine and then look for fresh oil as it runs.
50 chrysler,54 Plymouth, 64 Valiant conv 4 speed, 66 Valiant V8 wagon, 70 Challenger R/T 440+6 conv 4 speed,80 Colt, 98 Neon ACR,84 Honda V45 Magna
Taking care of 57 300C conv,48 T&C conv. Missing my 67 GTX and 36 Ply coupe
PostPosted: Tue Oct 05, 2010 5:30 pm
I tried that but it doesnt leak when it idles, only after I drive it for a while. Then when I try to look for the leak I cant find it cause the whole engine bay is covered in oil lol
PostPosted: Tue Oct 05, 2010 6:08 pm
Take the oil fill cap off, start the engine and see how strong the air flowing out of the oil fill hole. Should not be much, this is known as the blow by test. Do you have a open or closed crank case? If closed check your pcv valve-does it rattle? It should. No rattle means replace it. If the pcv system is not working you can over pressure the crank case and cause a lot of leaks all over.
Overheating can be caused by to much timing, to lean of a gas mixture, poor water circulation or plugged exhaust even a really worn out engine. How many miles? Have you done a tune up on it?
PostPosted: Tue Oct 05, 2010 7:05 pm
I did a full tuneup on it, everything except spark plug wires (they were the wrong ones). Exhaust isnt an issue because im basically running open header... it fell off lol.
And the car has 197,000 miles on it but 40,000 on a full rebuild. Not sure if its open or closed crank case. its a 3 speed auto if it makes a different. Could you tell me where the pcv valve would be located?
1965 Plymouth Belvedere II- Project Car
1992 Mitsubishi 3000gt VR4- Show Car
2004 Chevrolet Corvette- Daily Driver
PostPosted: Tue Oct 05, 2010 7:19 pm
If you have a closed crank case you will have a about 1" hose that goes from the valve cover to the air filter housing. And a second hose coming from the valve cover to the base of the carb. The second hose will have the pcv valve on the end that goes on the valve cover. If you instead have the open crank case you will have a steel tube coming of the back of the valve cover next to the fire wall and going down the side of the engine toward the ground (it is called a road draft tube).
PostPosted: Tue Oct 05, 2010 7:29 pm
When you did the tune up did you set the points by gap or dwell meter?
PostPosted: Tue Oct 05, 2010 8:39 pm
Set them by gap
PostPosted: Tue Oct 05, 2010 10:30 pm
You can overheat that engine easily if your timing is too far off. Sounds like you're at least narrowing down the culprits.
Check your oil sending unit. If you have an idiot light, those are known to spray oil when they go bad. they can still function normally and spray oil all over. DAMHIK> :roll:
PostPosted: Wed Oct 06, 2010 7:26 am
If you have a lot of experience with points that should be ok but if you do not, use a dwell meter-a little off on the gap can cause a big problem .
Yes I forgot that the oil sender can leak
PostPosted: Wed Oct 06, 2010 9:20 am
Where would I find the sending unit? my car has an oil pressure gauge but its blank... like it was an option and my car didnt come with it
PostPosted: Wed Oct 06, 2010 10:21 am
If the breather & PCV valve are plugged / non-functional, then crankcase pressure can build-up and force oil out the dipstick tube... this makes a big mess in the engine bay.
Test for proper PCV and breather function and repair / replace as needed.
There is also the possibility that the engine has a ring sealing problem and that can cause excessive crankcase pressures.
PostPosted: Wed Oct 06, 2010 1:37 pm
You should have a "idiot" light. If you turn on the ignition key to "run" with out starting the engine you should see a red light light up with the word "oil" on it. The sending unit is near the bottom of the block, single wire. The only other sensor will be in the head for water temp.
PostPosted: Sat Oct 09, 2010 9:43 am
Little update. I found out where the oil was leaking from.. It is actually not oil, it is trans fluid. My radiator is completely destroyed, so fluid is leaking from the trans cooler when at high speed and is hitting my fan, which then slings it all over my engine bay. That is also why I am having an overheating problem as well. So i guess that solves the mystery. Now i just have to find a radiator, which is proving to be quite the task.
PostPosted: Sat Oct 09, 2010 11:24 am
If your top and bottom tanks are ok any radiator shop can put in new tubes. They can replace the tranny cooler too!Or try the local discount auto parts stores
