It is currently Tue Nov 24, 2026 12:35 am
PostPosted: Thu Oct 07, 2010 5:42 am
All - I have a base 1972 Dart. Slant 6, 225c.i.
I drive it about 3 days a week into work, and it runs like a top. It had 39k original miles on it when I bought it. Near mint interior, trunk, etc. Engline-wise, my previous owner had just done a valve job and tune-up.
Now when I'm driving I get a discernable tick-tick-ticking sound that increases as I accelerate.
Is this pinging? I use a 93 octane gas in it, but perhaps need an additive.
Is this the valves?
What is this? And how can I fix it?
Thanks for any help here you can provide.
PostPosted: Thu Oct 07, 2010 6:02 am
First item in the 'can't hoit' department is a valve adjustment. Read this: http://www.slantsix.org/forum/viewtopic ... ght=#72139
There is nothing more exciting than adjusting the valves on a slant six while it's running! Just don't wear a tie, and if you're a rocker, pull back your hair. :wink:
If that doesn't work, try a high-quality manifold gasket, like a Remflex or Aussie speed, search for them on this forum.
PostPosted: Thu Oct 07, 2010 6:04 am
If the ticking gets louder the harder you step on the throttle, it is probably an exhaust leak around the manifold.
PostPosted: Thu Oct 07, 2010 6:31 am
How hard is a gasket change on the manifold?
PostPosted: Thu Oct 07, 2010 6:41 am
The Intake/Exhaust manifold can be a task. THe manifold bolts are hard to reach and can be broken off easly. See the articles section for a great write-up on how to do this. Start using PB Blaster now on ALL the bolts. Dont worry it doesnt cause fires or burn.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Oct 07, 2010 8:04 am
one trick i have learned for checking exhaust manifold leaks is to pour a little seafoam down the throat of the carb while the engine is running
just a little bit as too much will shut the motor down. you should be able to see any exhaust manifold gasket leaks by smoke coming between the manifold gasket and the head.
PostPosted: Thu Oct 07, 2010 8:20 am
Can you hear the ticking at idle ? Does it "clatter" at higher engine speeds? You should only need to run regular grade gas in your /6. Pinging is heard best when you go up a steep hill, low engine speed and wide open throttle but do not down shift. Trailing throttle (coasting down a hill) and pinging will go away.
50 chrysler,54 Plymouth, 64 Valiant conv 4 speed, 66 Valiant V8 wagon, 70 Challenger R/T 440+6 conv 4 speed,80 Colt, 98 Neon ACR,84 Honda V45 Magna
Taking care of 57 300C conv,48 T&C conv. Missing my 67 GTX and 36 Ply coupe
PostPosted: Thu Oct 07, 2010 11:34 am
I actually don't hear the ticking a idle. It's more of a clatter when I'm accelerating. So far I'm hearing Valve Adjustment, Manifold Gasket or possibly gasoline as causes. I'm leaning toward redo-ing the manifold gaskets first, then perhaps a valve adjustment (or both). Don't have that much time with a 5, 3 and 11 month old but I can fit it in after 8.
PostPosted: Thu Oct 07, 2010 5:17 pm
I'm also thinking it is an exhaust leak somewhere.
'68 Dodge Dart 4dr Sedan
PostPosted: Sat Oct 09, 2010 1:35 am
Whats your timing at? Back it down to TDC and then drive it around the block and see if the sound goes away. If it does go away then you were probably pinging. Might as well try it before you pull your wallet out.
Users browsing this forum: Amazon [Bot], Google [Bot] and 5 guests
