It is currently Tue Nov 17, 2026 5:28 pm
PostPosted: Thu Oct 07, 2010 10:14 am
Is there a socket for the TF 904 front band adjustment screw? The screw has a square end and it is quite difficult to adjust the correct torque without a socket which fits in to that screw and torque wrench.
Where can you buy it?
PostPosted: Thu Oct 07, 2010 10:52 am
a 8 point 1/4" socket should fit.
PostPosted: Thu Oct 07, 2010 2:44 pm
Break the locknut loose, screw the band adjuster down a good finger tight, back off 1-1/2 turns, tighten locknut. :D
 Post subject: -
PostPosted: Thu Oct 07, 2010 10:27 pm
8 point 5/16" socket.Most chinese 1,001 piece socket sets have these.Just remember the factory specs of 41 inch LBS then loosen it X amount of turns is for use with the factory adapter tool that alters the torque reading of your torque wrench.Check the 7 digit part # of your trans,then obtain the correct service manual for the model year.Then notice possible torque spec differances between S/6 and V-8 904 transmissions.
PostPosted: Fri Oct 08, 2010 3:40 am
Thank you for the answers. We have two canditates, 8 point 1/4" and 8 point 5/16, I will try both and hopefully one of those will do the job.
I have the FSM and the correct torque spec.
PostPosted: Fri Oct 08, 2010 4:34 am
Why wouldn't a 12 point work?
PostPosted: Fri Oct 08, 2010 2:25 pm
It will. :D
PostPosted: Sun Oct 10, 2010 6:22 am
+1 Listen to Dennis
He has done more than one. and this is EASY!!!
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sun Oct 10, 2010 8:08 am
Dennis' version of finger tight = 150ft/lbs........
