It is currently Mon Nov 23, 2026 2:39 pm
 Post subject: Erson 284 camshaft
PostPosted: Sun Oct 10, 2010 7:21 pm
hello i was wondering what the specs are on this cam i keep seeing everyone talking about these cams in other posts.
PostPosted: Sun Oct 10, 2010 7:36 pm
Site Admin
There is a link in the Frequently Asked Questions. All the mainstream Erson grinds are there.
You will find other grinds talked about in that thread, like RDP grinds that work very well with six cylinder engines.
The one you are suggesting is pretty big. What are your goals here?
To carry something that big you will need to build your static compression, flow work, perhaps oversize valves, shorter gears, and a high stall converter.
That would not normally be a street cam.
CJ
PostPosted: Sun Oct 10, 2010 8:22 pm
looking for a bigger cam than my comp 273 adv. 236@050 .501lift, just not big enough and i want a way rougher lopey idle, i'm running super ported head,360 valves,double springs,10.5:1 compressin,headers,3in exhaust,650 edlebrock 4barrel with 2in. carb spacer, 125hp nos, 3.55 gears, 3800-4200 stall converter
PostPosted: Sun Oct 10, 2010 8:27 pm
Site Admin
Sounds like your able to run that cam. :wink:
Did you find the profiles in the Erson Group Buy thread?
Find a true roller to keep it in time. The gear drive sounds cool, but the timing accuracy isn't on a par.
If that cam doesn't make it sound wicked, nothing will. :lol:
CJ
PostPosted: Sun Oct 10, 2010 8:29 pm
i cant find the specs on that cam would it be more wicked than what i have now? i email comp cams to asked them but then i saw this stuff. do they offer a roller set up?
PostPosted: Sun Oct 10, 2010 8:42 pm
Site Admin
I don't know. I don't currently run anything that radical and only know the 252 and 264s.
I kept my plates on the car, and can putt up to the track while still pulling 19 or 20 mpg with my RDP RV15M.
Someone will chime in that has those bump sticks, I'm sure. :D
The advertised duration isn't what I'd be looking at. Pull the data for the .050" lift events, then look at lash and lift together. Make sure to look into where your springs bind before getting into the higher lift cams.
Dependent on your head flow, but limited by the designs of our particular head, the bigger lift numbers aren't necessarily the key.
Lot's of folks like the Erson RDP 280/270 or smaller for street use. Keeps the fuel flow within reason.
I sold the High Flow AM 'Zilla provided me to DusterIdiot. We'll see if he's got an update on his engine autopsy and plans to proceed. That's a big numbers cam from Erson. Hopefully he'll find something rebuildable inside after his oil failure.
I was going to get Guzzi Marks de-geared cam, but he went another route. I may be stuck back at square one finding a nasty cam now. :lol:
I've got a complete Erson 280 Kit sitting in the shop. It's a bit mild for the new build though.
CJ
PostPosted: Mon Oct 11, 2010 5:59 am
I had a regrind made by Oregon Cams but haven't run it yet:
250 @ 0.050", 0.494" lift INT (lobe # 34)
249 @ 0.050", 0.480" lift EXH (lobe # 1628)
105 deg LSA
Degree at 100-102 centerline.
I designed this based on lots of data and picked lobes off Oregon's list. Should be perfect for 10.5:1 comp. I believe they can put a little more lift on it if you like too. Rick Covalt may have bought one like this recently with their updated lobes with a bit more lift.
If I want bigger, I'll be getting a 255/249 @ 0.050" from Oregon.
PostPosted: Mon Oct 11, 2010 6:29 am
249 @ 0.050", 0.280" lift EXH (lobe # 1628)
105 deg LSA
Lou, are those lift figuse correct?
 Post subject: Cam
PostPosted: Mon Oct 11, 2010 7:20 am
I believe that exhaust lift was to be .480 lift. I did have a cam reground with a little more lift. I will get the specs for you this evening.
Rick
Found it over on the Virtual dragstrip
Intake 250 @ .050, Lift .513
Exhaust 243 @ .050, Lift .506
LSA 105
PostPosted: Mon Oct 11, 2010 8:32 am
Oregon Cam Grinding profiles are listed in this thread:
http://slantsix.org/forum/viewtopic.php?p=191616
I believe Oregon has wilder cams available. This is just the first sheet of their mechanical grinds. They can also do hydraulic profiles, locomotive camshafts, etc.
Lou's cam appears to be:
Intake lobe #34: 250° @ .050", 288° @ .020", .329" lobe lift, .494" @ 1.5:1, .020" lash.
Exhaust lobe #1628: 243° @ .050", 275° @ .020", .320" lobe lift or .480" with a 1.5 rocker, lash is .018".
I have Oregon #791 ground as listed and installed on 102.5° intake centerline in a 9.7:1 CR 225. I chose equal intake and exhaust duration as I'm going to use nitrous which will be helped by the increased exhaust duration.
PostPosted: Mon Oct 11, 2010 9:08 am
Charlie,
I edited - now correct.
Thanks,
 Post subject: Mine too
PostPosted: Mon Oct 11, 2010 6:17 pm
I edited mine too. It is now correct. Old age is great!
Rick Covalt
