It is currently Sun Nov 22, 2026 3:25 pm
 Post subject: Over heating
PostPosted: Sun Oct 17, 2010 4:08 pm
My van overheats when I am on the freeway for more than 15 minutes. At that time the temp is gradually raising. But when I get off the freeway it starts cooling down and is in normal range in a few minutes.
This happens when the outside temperature is over 80 degrees. On cool days this is not a problem.
Is this a radiator or water pump problem? Or something else?
1975 Dodge B200 Van SWB, 3.7L /6
1960 Ford Ranchero - Boss 302. 4spd
PostPosted: Sun Oct 17, 2010 10:34 pm
Clogged radiator or thermostat isn't opening enough.
Take out the thermostat and see what happens. (test in boiling water while you're at it)
