It is currently Sun Jun 14, 2026 12:11 am
 Post subject: Rough Idle
PostPosted: Sat Oct 16, 2010 12:25 pm
Hey just joined this forum today...
Got a 1966 Dart with of course a slant six. Well, it seems I'm baffled...
It has a Holley carb on it and I cannot get this sucker to idle right. I get a good idle in neatral then when I shift into Drive the idle falls on its face. Any suggestions
PostPosted: Sat Oct 16, 2010 3:36 pm
Adjust the valves........
PostPosted: Sat Oct 16, 2010 6:04 pm
ditto
1954 Ford, Tudor Mainline
1976 Plymouth Valiant, 4 door
www.automotive-ninja.com
PostPosted: Mon Oct 18, 2010 6:13 am
After you adjust the valves. Check your fuel system trash in the tank or line or ....
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Oct 19, 2010 7:22 am
wondering if timing could effect it also, I cannot turn the dist. enough to time it correctly , maybe the dist. is in wrong ???????? maybe??? off a tooth or so???
PostPosted: Tue Oct 19, 2010 7:24 am
Or the Damper can slip. You need to get the #1 to TDC compression and work from there.
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Oct 19, 2010 8:43 am
Once you know the damper is OK, you may need to loosen the other bolt, on the bottom of the distributor, in order to get more travel and the correct timing adjustment.
And yes, also check the valve lash adjustment.
PostPosted: Tue Oct 19, 2010 9:36 am
adjust the valves first.....it's easy and regardless, the car probably needs it anyway.
Users browsing this forum: Bing [Bot] and 6 guests
