It is currently Sun May 10, 2026 1:08 am
PostPosted: Wed Aug 06, 2003 6:46 pm
I was going to replace just the front half of my strut rod bushings to get rid of some of the extra play. The replacements from NAPA was a one piece bushing? It is smaller on one end than the other, is it supposed to replace both halves and install from the front so the LCA doesn't have to be removed? Or did I get a wrong part? Has anyone seen this type of bushing?
Cecil
PostPosted: Wed Aug 06, 2003 8:30 pm
...go back and see if they can get you the two-piece, it's a better setup. MOOG comes to mind. I don't know what NAPA sells, but it may be the same stuff. Anybody know a part #?
'I hear you' on just replacing the front half :) It's very simple, and that's usually the half that gets shot. Done that myself to hold me over until I felt like yanking everything apart (which would be never, if I could help it). Check your lower control arm bushings, though. If there's been a lot of slop in the strut rods for long, it may be shucking out the LCA bushings, too.
"DW"
If it ain't broke, fix it!
PostPosted: Wed Aug 06, 2003 8:48 pm
The MOOG two piece bushings are very nice - metal inserts and big beefy rubber. I've never seen a one piece one that I thought was worth anything, since they have all been 100% rubber.
 Post subject: stock
PostPosted: Mon Aug 11, 2003 7:49 pm
While the original bushings are a 1 piece design, I don't have any regrets about using 2 piece poly ones from Energy Suspension on my Dart.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
 Post subject: ?
PostPosted: Wed Aug 13, 2003 10:11 pm
It used to be the moog ones with the steel inserts were called 'hi perf' or something like that. the std ones were not nearly as well designed.
'66 Cuda 225/4spd
'64 Dart GT 340/4spd
PostPosted: Thu Aug 14, 2003 1:28 pm
Cecil,
The Moog Part number for the strut rod bushing is K-7068.
They are $24.67 at Central Auto parts.
John
