It is currently Mon Jun 22, 2026 1:04 pm
PostPosted: Tue Oct 26, 2010 7:51 pm
Glad to hear it! You can leave the ballast resistor in there, and that will depend on the coil you are using as to whether it requires a ballast. Just make sure the hot (red) wire for the pertronix goes to a true 12V switched source, and not the downstream end of the ballast.
I goofed this once and it kinda ran, but backfired and stalled.
PostPosted: Wed Oct 27, 2010 12:42 pm
Eppy25,
As Lou pointed out you can buy a 3 ohm coil from them. I did and tossed the ballast resistor. They have a couple of different 3 ohm coils. I am using the HEI version. If you would like to see some pictures of the change, click on the red link below my name.
PostPosted: Wed Oct 27, 2010 5:11 pm
thanks to everyone for the advice. car starts and runs great. the pertronix ignition system and flame thrower 2 coil are in and its such an a amazing difference with that valve job.
~EPPY~
PostPosted: Thu Oct 28, 2010 5:12 am
Excellent! Glad to hear it.
