It is currently Sat Nov 21, 2026 9:38 am
PostPosted: Wed Oct 27, 2010 8:50 pm
Hi all
Im looking for air filter housing for my 1966 Dart Convertible and was wondering are they all the same? i mean say 1963 vs 1972? I found this on ebay:
http://cgi.ebay.com/ebaymotors/1976-77- ... _500wt_956
Will it fit my 170ci engine?
Cheers
Syed
Cars: 1966 Dodge Dart 270 Convertible,
1990 Alfa 164 Twin Spark
1980 BMW 735i 5-speed
http://www.weddingcar4u.blogspot.com/
PostPosted: Wed Oct 27, 2010 10:17 pm
No, that air cleaner is very much different than your original which looks like this:
PostPosted: Thu Oct 28, 2010 9:33 am
It should fit, and would allow a cold air hose the stock air cleaner wouldn't allow, but it looks nothing like the stock one.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Thu Oct 28, 2010 9:50 am
Not necessarily. The center hole on the air cleaner did change over the years for the 1920 and 1945 carbs. Different years had the snorkel pointing different directions and this was controlled by the shape of the flange on the air cleaner housing. Further, some air cleaners had special dimples stamped in them to clear choke linkages and if the air cleaner is not oriented correctly on the carb or is used on the wrong carb there will be clearance problems.
Many air cleaners do interchange, but I would recommend test fitting a new one on your car before you buy. Cold air and heated air intake provisions are great upgrades, so long as the air cleaner will fit your carb and clear your accessories.
PostPosted: Thu Oct 28, 2010 1:15 pm
If you need the correct air cleaner assembly for your 66 Dart, send me a PM.
I have a bunch of them in the shed.
PostPosted: Thu Oct 28, 2010 4:13 pm
When all else fails, just make it out of a hubcap like this car 8)
http://tinyurl.com/2b9clew
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot], Google [Bot] and 6 guests
