It is currently Fri Jul 17, 2026 10:13 pm
 Post subject: Lexan Rules / Thickness
PostPosted: Fri Oct 29, 2010 12:52 pm
Hello Does anyone know the Rules For NHRA / IHRA Lexan Thickness for Front, Rear and side windows on a door car?
I just dont want to go ordering the wrong stuff.
Thanks!
PostPosted: Fri Oct 29, 2010 1:16 pm
I believe minimum for side and rear are 1/8" (or 0.120"?). That's what I have on Project V. Windshield may be thicker, but can't remember. I know it is thicker for SCCA and NASA.
PostPosted: Fri Oct 29, 2010 2:10 pm
Cool - The stuff I have seen so far is 1/8" or 3/16"
So I'll plan on getting 1/8" for sides and rear and possibly 3/16" for front.
PostPosted: Fri Oct 29, 2010 2:15 pm
You are better off with 3/16" at least in the windshield. Side windows 1/8" is normal.
That is what my Pro Glass kit from Glasstek is, and the windshield and back glass are molded.
PostPosted: Fri Oct 29, 2010 2:49 pm
Where are you planning to order from. Looks like prices vary a Lot.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Fri Oct 29, 2010 6:19 pm
How much weight difference when replacing all the glass? Later
Ryan
10.74 @ 127.47 mph 1320 ft
6.65 @ 107.80 mph 660 ft
http://www.youtube.com/c/turbo66valiant
Follow on Instagram - turbo66valiant
Facebook - https://www.facebook.com/ryan.peterson.737
PostPosted: Fri Oct 29, 2010 6:59 pm
If you get rid of all mechanisms and go to lexan, I figure sides and rear on a mid 60s car save about 60-80 lbs. Windshield will be around 15-20 lbs. I'd have to look back to get exact numbers... I weigh everything.
We pulled about 15lbs of undercoating out by stripping the whole Project V inside and underside. I have not gotten too serious with this car and even with 110 lbs of rollcage it is 2490 without me, but with 12 gals gas. Still has glass windshield+gasket in it and stock steering column. 50-100 lbs more out of it should be no problem.
PostPosted: Fri Oct 29, 2010 7:15 pm
1/8th is legal,have been 115mph with 1/8th windshield.Mark
PostPosted: Fri Oct 29, 2010 7:39 pm
Good Discusion Here guys.
I was looking at summit for just lexan / polycarbonate sheets. the long 72" X24" sheets are about $100 a piece - I also have to stop in the local storm door shop too.
I guess I could get one of the pre molded Windshields for the front Windshield for ruster, but it's like $375 - $400 range..
The side and back should be eailsy cut from sheets.
I am also looking to get rid of most of the metal frame around the doors except for the driver's door and just totally cut and gut as much as i can from the rear doors. - I might even get rid of the rear hinges and just weld the rear doors shut once cut and gutted.
PostPosted: Mon Nov 01, 2010 8:29 am
SL6 Racer
The windshield on my 70 Cuda is 21 lbs stock 11 lbs. 1/4 inch pro glass. Not worth it .The sides in 1/8 inch save about 3 pounds per door and 2 in a 64 sedan. However the cranks and other stuff you can cut out will amount to about 50 lbs total on a A body. For the side windows the best deal i have found on !/8 inch is from glass installers remnants. Make a card board template and take it to different shops, MY 64 all four sides were about $20 .
Users browsing this forum: No registered users and 32 guests
