It is currently Fri Nov 20, 2026 7:35 pm
 Post subject: Carb help
PostPosted: Tue Nov 02, 2010 1:05 am
Hi,
So i want a 350 holley to go in my 225 VC Valiant.
Currently the car has a new ignition setup with bigger coil extractors and the head has been ported and polished. When I get the new carb I'll of course put on a new manifold perhaps a long runner from aussie speed?
Either way I also plan to shave the head to 10:1 compression and install bigger valves 1.77 and 1.44 I think the standard upgrade is.
is a 350 holley too much...?
And the big question is where should I get it from...? All I hear is that REMAN carbs are terrible... so Advice on this would be great. I'm in Australia but would be happy to pay for shipping etc.
PostPosted: Tue Nov 02, 2010 4:29 am
Here is a new one: http://www.summitracing.com/parts/HLY-0-7448/ It should be fine with your set-up. Now that you have decided on a good intake, carb, ignition, and higher compression, your limiting factors will be camshaft and exhaust.
PostPosted: Tue Nov 02, 2010 4:46 am
Oh I also forgot to add, have installed extractors and will be putting a 2.5" exhaust setup in :).
PostPosted: Thu Nov 04, 2010 6:35 am
Since you're in Aus, try Hume Performance. Their recon carbs are pretty good, as are their new carb prices. http://www.hume.com.au/
62 Valiant, 225cid Slant 6/PB 904 with lots of good bits
http://www.moparmarket.com/readersrides ... user=SV162
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 3 guests
