It is currently Sat Jun 06, 2026 4:21 am
PostPosted: Tue Nov 09, 2010 11:44 pm
Car Model: 1973 Plymouth Valiant Sedan
I understand that diagnosing a loose timing chain can be done by turning the engine by hand and watching how quick the distributor is to respond.
My question is:
What could one expect to be the symptoms they would experience in regards to vehicle performance if a timing chain was becoming significantly loose?
THANKS!!
-Matt
PostPosted: Wed Nov 10, 2010 8:39 am
A worn timing chain and gears will retard the cam timing so the engine will loose "off-idle" and low RPM performance.
PostPosted: Wed Nov 10, 2010 6:55 pm
If it's really sadly worn, like on my wife's Dart, it leaks oil through the timing chain cover where the chain was so sloppy it wore a hole in the steel cover!!! (Yes, I changed the chain and cover.) :oops: :oops:
PostPosted: Sun Dec 12, 2010 7:16 pm
im shure the same principals apply - but I had a pontiac motor that stretched its timing chain so badly I couldnt believe it was still running when I pulled the motor out.
it would seem verry erratic with the ignition curve / meaning taking off from a dead stop was usualy met with some frustration and power loss and the biggest give away was de celeration - during deceleration the engine will develop a nasty back fire - since the stretched timing chain will allow the cam to advance it self during this - and retard it self during acceleration.
1972 Plymouth Valiant / slant 6 auto
