It is currently Sat Nov 21, 2026 3:52 am
PostPosted: Fri Nov 12, 2010 6:12 am
I just recently purchased a NOS radiator for my 71 Duster 225 slant six. It didn't come with a NOS cap and I'm not sure what cap I should be looking for. I don't have an owners manual yet, and I'm confused by the various reproductions available which all claim to be concourse correct. Can anyone tell me which reproduction cap I should be looking for and what pressure it is rated at? Thanks
PostPosted: Fri Nov 12, 2010 6:14 am
Pressure is 16 lbs. Check the Year One manual on line for the a stock OEM Cap.
 Post subject: Radiator cap
PostPosted: Fri Nov 12, 2010 9:36 am
Thanks. I've been to Year One's website and they offer several reproduction radiator caps for 1971 A-bodies with a/c and without overflow containers. What also makes this confusing is that I see the same caps on Ebay for a fraction of what Year One is asking. I could spend from $15.00 to $65.00 and they all look alike. I guess I'll just purchase one at the $30.00 level and hope for the best. Thanks again for your help.
PostPosted: Fri Nov 12, 2010 12:52 pm
The 16# Stant cap is stock. Basically all silver with a brass center button. That is what I am using......
PostPosted: Fri Nov 12, 2010 1:49 pm
I just put brand new radiator in my 77 Aspen. The radiator guy told me to run a 13 and gave me one as he lost my new 16 lb Stant that I got from NAPA that was on my old radiator. He thought that 16 lb was a little high, which I did also until I checked my service manual. He also gave me a new 15 lb which is what I will probably run. On the type it depends on how original you want to keep it. Mine is a 200.00 daily driver so it didn't have to be original. Well with everything tallied including new to me hood, grill, fender, radiator due to hitting a deer last week and everything I've done to the car. It is now a 1000.00 car LOL
Thanks Mike
 Post subject: radiator cap
PostPosted: Fri Nov 12, 2010 2:45 pm
That was a dear deer!
PostPosted: Fri Nov 12, 2010 5:44 pm
A 16# cap provides a little more freedom from overheating in traffic (I have some nasty commutes, lots of stop and go) when running a 195 degree stat. It also works well with my 205 degree stat.
PostPosted: Fri Nov 12, 2010 11:51 pm
I bought a 16# reproduction cap for $35.00 which is middle of the road when it comes to cost. I also got some very helpful information from this forum about the proper thermostat to buy. Thanks for the conversation!
PostPosted: Sat Nov 13, 2010 7:45 am
I was advised that I should get a 7# cap... what do you guys think about that? 1970 225, 52000 miles.
PostPosted: Sat Nov 13, 2010 8:02 am
My radiator guy use to advise a 7# cap, and a qt. of water pump lube in my service trucks whenever he got his hands on them. The vans were mostly high millage junk. I think his theory was; not so much boil over temperature problems (high temperatures & stalled traffic jams are not a problem in Maine), but blowing out old water pump seals, heater cores, and hoses.
I would stick with the 16# cap. If you have been previously using a lower pressure cap in conjunction with old parts, and step back up to a 16# cap, a weak link could possibly let go, but it was on its way out anyway If all the cooling system parts are new, there will be no problem.
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 9 guests
