It is currently Wed Sep 16, 2026 12:59 pm
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Sat Nov 13, 2010 8:44 pm
Hi Ed, I got the ciruit via e-mail. Thanks a bunch.
They say if you run the exhaust for too long without power to the sensor itself, that you can burn it out. What have you heard about that, and are you concerned about this in waiting to turn the LC-1 on?
Sam
Your welcome 8)
As for the delay, I figure with 2 minutes, any condensation will be gone, and things will just start warming up, but not yet warm enough to do any harm against an off sensor.
Most likely the burn out problem is with WOT against an off sensor.........
PostPosted: Sun Nov 14, 2010 2:52 am
I waded thru the innovate forum about the delay.........
The problem with running a car with the sensor off is when it's unheated, carbon clogs up pores in the sensor, effectively killing it.
They say it takes at least 15 minutes before it possible to clog up the sensor enough that the heater will have problems burning out the carbon clogs.
If you're running with the sensor off under 3-5 minutes, the sensor won't have any trouble burning off any carbon it's accumulated.
Another thread mentioned 120 seconds.............
